Question about Toshiba TheaterWide 46HM94 46" Rear Projection HDTV
How can u tell if the power supply is going out?? it has a wavy piture when u turn it on but it clears up after 5 min but ive noticed is taking longer to clear up... also when u change it to an input( dvd,playstation) when the screen is black u can realy see the waves.. ther blue if that makes any diff. i also want to know if u can still get parts for this tv thanks-phi//
    Top Expert:
  • Toshiba Master
  • 75,774 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Posted on Aug 26, 2017
  • 1694 Answers
SOURCE: Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Posted on Sep 29, 2007
djnick989
  • 1067 Answers
SOURCE: Vertical lines
hair line cracks in motherbord on soldering jobs look all over re soilde rthem back togther nicely
Posted on Jan 29, 2008
  • 1030 Answers
SOURCE: bad picture until tv warms up
this is a very common occurance in these sets. toshiba has issued a servece bullteen with this set. Sorry to tell you this but this is a problem with some very small capacitors on what is known as the hypermodule. in my shop we fix 2 to 5 of these a month. you really have to know how to solder. Idealy replace the hypermodule is the best way. but......that board is hard to find. so we replace these 11 very very small componets with twezzers and a big magnifier. we charge about 250 to 350 for this repair.
Posted on Oct 08, 2008
  • 41 Answers
SOURCE: Toshiba Theaterwide HD 52 in rear projection TV,
Possibly bad electrolytics. Generic answer but you didn't give a complete model number.
Posted on Jul 07, 2009
  • 668 Answers
SOURCE: wavy line or scrambled picture when l turn the tv
If you have a normal picture with lines through it, or if the picture jumps, tears or rolls, you have a Hyper Board that is failing. The last I checked, the Hyper Board is not available from Toshiba and has not been available for a number of years.
I hope this helps,
Skyassoc
Posted on Feb 08, 2010
Get no current to coil.....
starting problem ,takes 4-5 times turning over engine then blue smoke comes out of exhaust ,is very reliable when got started though -
ive replaced battery/glowplugs-&-relay/
a recovery man says no power to glowplugs ?
can you advise ?
Nov 29, 2012 | 1990 Dodge D150
Bad picture until tv warms up
well its a problem fo an ic causing the issue that needs to be replaced
May 30, 2008 | Toshiba 57HX81 57" Rear Projection...
Graphics wavy and sound sometimes not clear after flash on mb
First of all try to update your mobo bios again but with a different bios file.
Your issue can be due to faulty bios update, if there is any option to revert back to your original bios then do so if not try to update your mobo again with more recent bios file.
Nov 29, 2012 | Computers & Internet
When I plugg my Hicon television up to my power supply and turn it on, it takes roughly 5 mins for the power supply to turn on. Is there a problem with the power supply?
Yes you are having a power supply problem and the culprit might be the main filter capacitor. On opening you might notice it would have bulged out and might be leaking.You will have to get it replaced.
Jul 14, 2011 | Televison & Video
My lg television switches back to stand by mode an have no pictur
Have the power supply checked for buldging capacitors on the power supplu, if you take off the back of the unit look near the power connector the goes from the Power supply to the main control board, you will find two capacitors that are starting to puff on their tops. The rating on the caps are 1000uf caps rated at 10 volts replace with 1000uf 16 volts caps instead.
Mar 03, 2010 | Televison & Video
Chevy cavalier wont start randomly! makes one click and a humm sound my lights come on the radio comes on but the car just wont start, ive had battery replaced along with the ignition switch, fuel pump,...
Ok then, from your description and the
make/model/year of the car you have there,
it appears you've reset the VATS.
The car's security immobilizer
reader at the key switch
does not recognize the coded
chip in the ignition key any longer.
You can try to put the key
in the ignition, turn to the on position &
wait at least 10 min like that.
(Do not turn off the key switch before
10 minutes as elapsed!)
Once done, the key is re-programmed and
should allow the fuel injectors to work again.
The car would start now if corrected.
In some cases, the VATS (GM'S VEHICLE ANTI THEFT SYSTEM)
will re learn the code this way, and will then
allow the restart, however if this does not work,
then you can simply tow it to any GM vehicle dealer
to have the service department re code it.
There is a permanent solution though.
Adding the PLJX Self learning Bypass module (59.95)
will bypass the PASSLOCK system in your vehicle
for good. See this at www.PASSLOCK2.com
Good luck I hope method 1 does the trick!
Here is the 30 min relearn:
Ignition keys relearn takes about 30 min to do. 30-Minute Learn Procedure 1. Turn ON the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON; the vehicle will not start. 3. Observe the SECURITY tell tale light. After approximately 10 minutes, the light will turn OFF. 4. Turn OFF the ignition switch, and wait 5 seconds. 5. Repeat steps 1 through 4 - two more times - for a total of 3 cycles of 10 minutes. 3x10 = 30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch turn from OFF to CRANK Important: Turn the Ignition Switch OFF. The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password. 7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles. Without a scan tool you may have momentary starter interruptions while history clears itself.
Dec 22, 2009 | 2003 Chevrolet Cavalier
Wavy picture
I need the model number to be sure. I am guessing that a 2200uf or a 3300uf capacitor in the main power supply is going bad. Call a good TV Tech and explain it to him. He should know where to find it and replace. Should cost around $175 at the most.
Jul 29, 2009 | Televison & Video
Set wont turn on, Beeps.
Try Resolder all of the Big Diodes around power supply.
Feb 18, 2009 | RCA P52960 52" Rear Projection Television
May 30, 2008 | Toshiba 65H81 65" Rear Projection...
53h71 toshiba projection TV with noise in picture
The problem you have is on the hyper module located behind the rear input panel. Inside the shield there are about 6 or 7 10mf/16v surface mounted capacitors. Replace them and your problem will be history. As for the shop that did the repair they owe you a call back to do it right. However, request that you get a different tech to come out. Do not attempt the repair yourself, it involves excellent soldering skills and parts removal. Good luck
Nov 17, 2007 | Toshiba 53H71 53 in. Rear Projection...
Toshiba TheaterWide 46HM94 46" Rear Projection HDTV Logo
159 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
