The piece of **** flashes the DSl light,(internet light goes out) I have tried every fuckign thing I...
(More)
The piece of **** flashes the DSl light,(internet light goes out) I have tried every fuckign thing I could think of and nothing works. Called the company and they said it was being overloaded, and they didn't tell me how to fix it at all.
I have dlink-dwa 130 it turns off automatic and has bad connection I always have to put the wireless...
(More)
I have dlink-dwa 130 it turns off automatic and has bad connection I always have to put the wireless router key? now it wiil not even turn on thru the USB ports - they are working I have tried other hardware in the same ports... what should I do-drivers are updated - I am corresponding thru my laptop not the computer having issues
Ok so i converted from Windows XP to Vista and when i noticed my connection was lost I unplugged and...
(More)
Ok so i converted from Windows XP to Vista and when i noticed my connection was lost I unplugged and plugged back in and it said that Windows could not Install the unknown device. So i went and downloaded Driver Detective which is supposed to "help" with that problem and that says i need an internet connection for that. So im am stuck on how to fix this problem an email for the solution will be greatly appreciated thank you
What distance from the router can I have my second computer hooked up and receive good signal. I Am...
(More)
What distance from the router can I have my second computer hooked up and receive good signal. I Am having an issue with the wireless netopia USB getting a (good) signal. The network icon on the bottom task bar indicates there is a good signal. However when I run the install disk after selecting the second coputer choice during the set up I receive a low signal and then the disk prompts me to type the last 3 digits of the SN# and then the 10 digit key. I do this and the computer states it is unable to make a connection. I have the second computer in a bonus room over my garage that is attached to the house. The 2 nd computer is around 60 to 80 feet away. What range can I expect?
