Question about Toro Lawn Mower With Toro Power Tools
The torque on my self propelled Toro Mower seems to not be self driving like it used to. It also is making a weird sound.
I agree with the previous answer. Likely the belt is off. Easy to fix and it happens pretty easy especially if you hit sticks or a branch and something (even a tiny stick or twig) finds its way under the plastic cover and gets into the belt area. Grab a pair of pliars, take off the bolt holding the plastic part down on the front and check the belt. If it is off or not alligned right, slip back on check debris. If problem is still there you may be looking at the actual drive shaft itself and that can be a real problem....the kind you may want to take to the local hardware store.
Posted on Aug 24, 2009
  • 508 Answers
Check belt for self propelled unit!!!
Posted on Jun 28, 2009
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
I have a toro commercial self propelled, engine stops when I engage the self propelled. I t runs until then. What can I do to solve this problem?
Regularly check the wheel-drive belt on a self-propelled mower for wear and tightness .... "Affected engines may run rough, stall or bog down under load,"
Jul 22, 2009 | Toro Lawn Mower With Toro Power Tools
I have a TORO 6.5HP Mower Model #20017 Self Propel Drive-
check cable.check belt and check gearbox.one of these will be bad.if not all
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Self propell toro mower will not "self propell."
Self propell toro mower will not "self propell", nor can i pull it backwards
Oct 03, 2008 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
278 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
