Question about Honeywell Programmable Thermostat Heater
I replaced my thermostat with a honeywell ct87n....it worked fine with the heat...I tried to turn it to the central air and nothing...turned on..not even my outside unit...any suggestions
  • taa43 May 11, 2010
    If the indoor blower runs when put in to cool auto set point below room temp then their some thing up with the out side unit Circuit breaker tripped or it is not wired correctly y stat to y on furnace g on stat to g on furnace @ the t stat make sure you have RH & RC jumped together good luck Tom
  • Melissa Griever
    Melissa Griever May 20, 2014
    we have the same problem, blower and outside unit will not even come on...any suggestions?
    Sergeant:
    Champion:
  • 232 Answers
Is there a jumper between RC and RH. you may have wired the red wire to RH and may be missing the jumper to RC
Posted on Sep 12, 2009
Ct87n thermstat is hooked up and the heater is on because i smell the heat but it is not blowing out the vent
The blower motor isn't running. At the thermostat, red wire to the R terminal white wire to W terminal.or W2 If the blower still doesn't run It's probably not the thermostat.
Nov 07, 2014 | Honeywell CT87N - Round Heat/Cool...
Honeywell thermostat blows cold air on heat
Thermostats don't actually blow anything, the heating system might though. Check the breakers for your heat system, then call a heating specialist. They're really not that expensive.
Oct 06, 2014 | Honeywell Heat/Cool Thermostat
Honeywell RTH2310b thermostate - my thermostat worked just fine through the winter with the heat but now it won't kick on the central air. I have tried switching the yellow(cool) and the white(heat) to...
You can check your float switch, power to both the air handler and outside condensing unit and ensure power is present, also check control voltage from transformer ensure 24Volts on secondary side. If you are not comfortable around electricity though I recommend you call your A/C Contractor for safety reasons.
Further information would be needed to further diagnose your problem.
Jul 05, 2011 | Honeywell Heating & Cooling
I recently installed the Honeywell ct87n thermostat.....the AC worked fine all summer, but has been off now for 6 weeks. When I turned in on to heat / automatic...nothing happens...neither the AC or Heat...
Check for a fuse in your AC/Heating system either on the control board or in-line on a wire. Make sure the wires are correct to the thermostat.
Oct 05, 2010 | Heating & Cooling
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
I put in a new honeywell thermastat my heat works but not my central air no power at all. when I turn it to cool will not even turn on air
What da ya got electric heat or gas heat? Did you buy the correct base for the thermostat? Who connected it? Honeywell is awesome but you need a pro to hook that sucka up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 25, 2009 | Weather King 10AJA2501AH Air Conditioner
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
460 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
