Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Agitator works, drum does not spin - Whirlpool LTE6234D Top Load Stacked Washer/Dryer
  • 351 Answers
Make any noise at all ? or simply just dont spin?
Posted on Jun 28, 2009
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Why is the agitator not agitating?
Is this a machine withwith an agitator & a fixed drum? If this is the case I would think that the drive belt has stretched or broken.
Jun 28, 2015 | Washing Machines
Its spinning but the water is not draining away and the clothes are still wringing wet
This usually indicated a problem with the pump. There is a belt which turns the agitator, spins the drum, and turns the pump, which is what removes the water. Since the agitator works and the drum spins, the pump is probably faulty.
Aug 02, 2013 | Indesit W 123 Front Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Drum won't spin, drains ok and agitator works fine
http://www.pcappliancerepair.com/model-display.php This site shows your lid switch. Just enter your model number. The lid switch is the usual suspect for your symptom.
May 09, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Washer will not agitate, took belts off and it will only spin one way.
Only one direction seems fine. On some machines there is a solinoid connected to a lever that either disengages or engages the drum brake to keep the drum from rotating during agitation. Some units reverse the motor direction when agitating and spinning. (one direction for spin the opposite for agitation. Most generally when the motor works in only one direction, say it spins fine but not agitating the culpret is the control dial. There are several combinations of electrical connections that must all make to go from one cycle to the next. On some other models there is a plastic cog that is moved by the solinoid to make the change. Without other info such as make and model, I can't really be sure how to tell you to diagnose the problem..The main thing is one direction is probably right on the turn question.
Feb 03, 2008 | Washing Machines
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
145 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
