Question about Sharp Office Equipment & Supplies
Getting u6-00 on arc172 checked all conectors switched m/c off/on no joy
  • 313 Answers
The error code is for paper miss feed or tray not set properly make sure you have the paper cassette is put in properly and that the paper guide plates at the sides of the paper are set properly and the guide at the back is holding paper in tray correctly o-pen the paper tray take it out and check this and then reset open the side door and close it correctly and this should help reset youcan check the paper feed rollers as well as sometimes they get dirty and will not feed properly you can clean these with a little glass cleaner and a soft cloth good luck A
Posted on Jun 30, 2009
Loader stuck in down position, the joy stick will not raise or lower loader. The joy stick will work the tilt movme
didnt specify type of machine( generic answer)some machines have an electrical assist joy stick check switchs if hydraulic check the r check fluid level in the hydraulics the tilt uses less fluid to the piston than the lift arms ----check the hydro lines and connections doesnt happen all the time but try bleeding lift lines air or debris in lines
Sep 15, 2015 | Cars & Trucks
Problem with the control of the rear windows; after a test, no polarity at the rear conector AVEO LT
Check the driver's door switch box. Any poor connections often originate here.
Nov 13, 2012 | 2005 Chevrolet Aveo
Front window switch came apart
that really sucks the clips that hold the pins on the wires are probably brocken if thats the case you can get a pig tai or even a new conector from the diealer or junk yard youl need the wireing scematics to replace the pins in the proper order most chevys have similar conectors with diferent wireing colors if you get it at the junk yard you can get the scematics for that rig and match them with yours hop this helped
Jul 22, 2012 | 1995 Chevrolet G20
1995 cavalier heater more quit working what can I do to test the moter?
First off check the fuse and the wiring to the motor, if no joy then try a new heater control switch to switch it on and off, these were always dodgy and were prone to failure, if you still get no joy then take out the motor wire it up to a battery they are only two wires for the motor to check the motor is working or not
Apr 26, 2012 | 1995 Chevrolet Cavalier
Brake lights do not work.Bulbs and fuses seem fine.
check the switch its located on the brake peddal arm up underneath make sure the electrical conector didnt get knocked loose. you may have to take it off and have it checked out with a multimeter if its not the switch you probley have a short. good luck
Aug 09, 2010 | 2008 Kia Optima
Changed radiator on94 honda civic now car
verify the plug of the fan and the fan switch located in termostat housing, if all are pluged in remove the conector of fan switch and short it with little piece of cable, if fan turn on replace the switch! it cost around $20. if the fan no turn on when short the conector verify if the fan conector have 12v if have it changer the fan motor if not check the fuse.
Jun 01, 2010 | 1994 Honda Accord
Brake lights won't work. fuse and bulbs OK
Check the brake pedal activated switch.
Dec 02, 2009 | 1984 Toyota Celica Supra
Will Not start in Park
The safety netural switch is loose there is a nut on the shift rail, if it is tight then the safety netural switch is bad and is held on with two bolts and takes 20 miutes to remove replace and adjust.
Oct 06, 2009 | 1999 Dodge Durango
LCD problem
JUST CHECK LCD CONCTOR IF LCD AND LCD CONECTORS ARE OK JUST CHECK THE VOLTS ON PCB'S LCD CONECTORS DEFINATELY PROBLUM WILL B SOLVED
Nov 15, 2007 | Nokia 3315 Cellular Phone
164 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
