Question about Dell (MOTHERBOARD7000)
No Problem just want specific dimensions on its motherboard size
Need dimensions for Dell 5150 Motherboard
    Sergeant:
  • 449 Answers
Visit http://www.dell.com and download the manual.
Posted on Jul 17, 2009
I have a Dell Dimension 5150 which has recently been taken out of storage to use again. It hasn't been used for a minimum of 2 years. Before it being put away it worked fine. The motherboard light is...
This is one of 3 possible problems. Either your motherboard has gone bad, your power supply has gone bad, or the connections from the power supply to the motherboard are not secure.
Nov 20, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 5150 will not start!
This is related to Hardware.
There might be a lose Ram of data cable connection on Motherboard.
This type of issue is also seen when the there is dust accumulation on Process Fan and CPU fan resulting in over heating.
This might also be due to malfunction of a motherboard.
The third reason could be that SMPS his not working.
Nov 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Can i up grade my processer on my dell dimension 5150 desktop computer and if so how big of a processer can i upgrade and is it easy to install.
Good morning! Yes, you can upgrade the processor of your computer but it will depend on the compatibility & support criteria of your computer motherboard, I suggest to check/review the product/operations manual of your computer motherboard which will inform us the details of specification requirements of processor that your computer motherboard will support & compatible with. Installation of processor is easy but with caution just follow the steps procedures written on its enclosed product manual, then make sure to install it with a good CPU FAN that will control its heat temperature. best regards.
May 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Upgrade cpu
It is a bit of a crapshoot trying to upgrade a processor from a major manufacturer. Their motherboards are designed specifically for the manufacturer and documentation on exactly what will work NOW compared to when the unit was new is rather hard to come by. They don't support people upgrading very well compared to the aftermarket manufacturers.
You should go to dell.com and put in your service tag to check your exact configuration yourself before spending any money.
According to Dell, the Dimension 5150 has a motherboard that uses the Intel 945G Express chipset. You can see INTEL'S documentation on that chipset's capabilities here. According to that documentation you can use a socket LGA775 with up to a 1066 MHz system bus speed.
Looking at Newegg, the fastest LGA775 processor with 1066 MHz are a 2.93GHz Duo core or a 2.4 GHz quad core. Again, no guarantees either will work with your system, and you definately want to make sure your power supply and case cooling are up to the task.
Mar 21, 2009 | Dell Dimension 5150 Intel Pentium 4 w/HT...
Dell 5150 - Options for upgrade
Usually motherboards corresponds to the Dell Number. You can change your motherboard alone from a local technician. However, that's strongly not recommended.
Jan 10, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell dimension 5150 won't start
See solution in http://www.fixya.com/support/t1372311-start_up_fault
Dec 20, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Change Motherboard For Dell Dimension 5150
If you replace with the same motherboard that's in already, that would be easiest for you.
But if you use a different one, you'll have to re-activate Windows, and download and install new device drivers.
Jan 09, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
Alun Cox
