Question about Whirlpool Dryers
Makes loud, squeaking noise when dryer drum is rotating
  • 351 Answers
Could be a roller or idler
Posted on Jun 28, 2009
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My dryer is making a loud squeaking noise when i turn it on
I would suspect the belt to be making the noise. If you are handy with a screwdriver, unplug the dryer, take the back panel off and have someone rotate the drum while you listen for the squeak. If it is the belt, get a can of belt dressing from your local auto parts store and lightly spray it on while rotating the drum so you get all parts of the belt.
Mar 29, 2011 | Dryers
ELectric dryer on any setting makes a "Rubbing or squealing"sound when turned on and inside "drum" is rotating. Does heat up, just very loud/ Whats wrong?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 21, 2010 | Frigidaire Electric Dryer
My dryer make a loud noise when its rotating
heatman101
jkgjh
Feb 16, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
Loud screeching noise from dryer.
sounds to me like the nylon pieces that isolate the drum from the front of the door are gone, you may want to open it up and take a look at it. Is it an old dryer? Its either that or I suppose it could be the bearing in the middle of the back but I dont think it would be in only certain parts of a rotation, it would be all. Im sure the drum probably just ate through the nylon seperator.Theres not much else that only makes noise part of the time.. and theres not many moving parts.
Im not sure if there are replacement pieces for this but you can google it.
Apr 13, 2009 | LG DLE2532W Electric Dryer
Squeaking noise
Noise from dryers can be eliminated through the following checks
* Level the dryer
* Check the drum belt
* Check the drum support rollers
* Check the idler pulley
* Check the glides
* Check drum bearings
* Check the blower
* Check the baffles
Apr 10, 2009 | Maytag Dryers
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
Dryers Logo
266 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
