Me and my boyfirend bought a new nokia 6288 today and we were loading files from our old phones to our new ones when suddenly our phones turned off so we tried to turn them on but now they just go to the nokia screen then flash a few times and then turn them selfs off please help!!!!!
Try this method for common N6288 bug. Remove your batteries, while
charger is unplugged. Remove the SD memory card from the phone and
clean it's gold/copper contacts with an eraser and then wipe it clean.
Put the battery back in the phone without the memory card. It should
turn back on, after it successfully turns on, put the memory card back
in.
If it continually happens, the memory card is damaged, or
you need a firmware upgrade for the phone, but I still think it's the
memory card.
Well some Nokia 6288 have known fault when accessing the memory card. Usually the fault happens either when theres too low battery and then recharged and it also happens after recharging.
The device automatically reads the sd slot just before booting thats why some 6288 will work after removing the battery, then removing the memory card, putting in the battery and fully recharge once again, without the memory card. After that the system boots itself up once again,. I have several serviced 6288 with this same problem, and have found this process to solve the problem. Maybe your phone problem is different, so don't say my answer is inappropriate... I know nokia phones from front to back, we are trained for it...
I know..
wells i had da same problem..
all i did was..
recharge it for 24 hours..becuase when i first got it, i kept playing on it and it over powered?
wells yeahs ..24 hours recharged..
and try turn it on..and if dosent work..i dont know thens
haha
sorry
Are both phones fully charged?
if so take them straight back
ok see budy ur handset is nokia s40 and it supports 3gp and mpeg formats, anything accept this will not work on ur handset, there is a software called"platovideo to 3gp" serach in google, u will get this easilytry this software dear.
nah it dont work AT all the memory card wasnt evn in it wen it happend to me.. i dont kno wtf ur on??? i mean how does the little memory card have ne thing to do with it?? it obviously gotto be internal
sorry i was just REALLY angry... i tried doing ur way lieka katrillion times.. then it dint work so i was liek RAWWRRR n skitz
so does that mean if i fully charge it without the SD card and turn it on it will wokr fine????
so does that mean if i fully charge it without the SD card and turn it on it will wokr fine???? coz it didnt turn on wen i followed ur last instruction, considering the SD card i only used once wen it broke and hasnt been in it since
after i removed my sims card and my battery and then place them back in my phone now wont shut on. i have a nokia 6126 please help
