Question about Fusion FEW12PK Car Subwoofer
When i turn up the volume the base cuts out and
When i turn up the volume the base up its cuts out then comes bk,
this is a new amp
    Problem Solver:
  • 7 Answers
Check and re check the grounds. You need a good solid ground. Sound simple, but we always seem to overlook the obvious... or Possibly the deck has a high output(rms watts) and is overpowering the inputs on the amp. In this case use a line out converter.
Posted on Jul 01, 2009
    Problem Solver:
  • 6 Answers
All depending on the size of your sub or amp the wattage just might not be powerful enough. 1st thing is just try putting a ground wire on a decent part of the car. ground/earth whatever you wanna call it
Posted on Aug 25, 2010
Jbl gto5355 amp cuts out at high volume
sounds like a bad ground. double check your ground and make sure its nice and tight, and make sure all the paint is scraped off and the surface of the ground is nice and shiny metal
Mar 19, 2013 | JBL GTO5355 Car Amp
Stereo cuts out
the cd player is old and its giveing out when the pre amp gets hot u should get a pioneer old or new they stand up to anything
Feb 14, 2013 | 2005 Dodge Durango SLT
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
It cuts off
amp maybe can't take the load ur puttin on it
Jun 02, 2010 | Alpine MRP-T220 Car Audio Amplifier
Ive got a jvc kd g140 and it cuts out at high volume.
did you hook this head unit up or did you have some one hook it up for you? most of the time it is that factory amp that makes it cute in and out. take the head unit out of you car and hook it up with a 12 volt power in your house or on you battary with a speaker and if it still cuts out the amp chip need to be replaced. let me know if this helped. thanks.
Kim ( Owner )
KS AUDIO
www.ksaudio99.webs.com
ksaudio-99@hotmail.com
Jan 15, 2010 | JVC KD-G140 Car CD Player
Subwoofer Turns Off when volume is turned up
check your earth from the amp i had same prob and the vibration broke earth connection once secured it was fine
Aug 24, 2009 | Pioneer TS-SWX310 Car Subwoofer
Amp keeps turning off
an amplifier needs minimum voltage (usually 6Amps) to turn on. If there is 12V at the input of your amplifier, check the remote for 12V as well as making sure the ground is secured. I suspect based on limited information, that your alternator/charging system is the culprit.Take your amplifier to a local shop and have it bench tested (abuot $10) they will hook up to an independant power supply and verify its properly working. Then it can be eliminated as the source of the problem. Also be sure your wiring and fuse are accurate for the amount of current draw.
Since your protection has never come on, and the power light is going out altogether, you may have an input voltage problem.
Dec 21, 2008 | Alpine MRV-F540 Car Audio Amplifier
Protection light coming on and amp cutting off
yes make sure there both connected properly, check the fuses, the protection light usualy comes on when there is too much power and the amp protects itself from blowing
Jul 16, 2008 | Car Audio & Video
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
On hold Music
On the Prostar 816 the MOH is connected to the BK-OR/OR-BK wires of the Female connector on the Base Champ Connector. You will need to connect the Headset jack connector to this location, that means cutting off the headset/ear piece from the wire and terminating it to the BK-OR pair of wires. Then MMC 309 and 408 are used to program the music on hold source to the stations and trunks.
Apr 11, 2008 | Samsung Prostar DCS-24B-LCD Corded Phone
Fusion FEW12PK Car Subwoofer Logo
203 people viewed this question
Top Fusion Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
hoyzee1
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
