Question about HP OfficeJet 7310 All-In-One InkJet Printer
How do I Replace print head - HP OfficeJet 7310 All-In-One InkJet Printer
I am getting an error telling me to replace all 4 print heads. I thought it was odd that all 4 would go out at the same time. Should i replace all 4 print heads or is the problem something else? Maybe
This is general problem in hp plotters..
understand the concept: If U R replaced any one of print head in good working printer, printer detects new print head & it will try to align it with others. Printer will print align page to read, while reading if its found any other print heads are poor quality or bad condition, it will say to replace them also.. Some times it may 2,3 or all.
If UR printer is trying to printing align page and reading it, definitely it will detects & displays the faulty /poor quality print heads. U have to replace it..
If UR feels its expensive, try to clean the print heads manually & try for UR luck...
Trailing cable error is 11:11...
Mar 24, 2014 | HP DesignJet 500 InkJet Printer
Printer heads errors
switch on the machine wait till error appears on panel, go to the system open internet explorer type IP address enter you can view the entire printer over view.. check which print head showing faulty, ask to replace the head open top cover of the printer open print head cover remove print heads clean print head contact pcb as well as carriage contacts insert print heads back then check for the print head recognition, printer will perform its own priming and all wait till ready mode comes onece ready mode appears.. print heads are OK.. if not replace faulty print head/s.Most of the cases cleaning is enough.
Jan 08, 2012 | HP DESIGNJET T1120 44 Printer
When making On, the printer displays a message W7100
this error code, stand for print head trouble.
You can try following:
1. Visual inspection:
Press down the BJ print head set locking lever to set it in a proper position if the
lever is pulled up.
Install the BJ print head if it is not installed.
2. Carriage unit
Visually check and replace faulty BJ print head set components or BJ print head
locking lever.
3. Replace the head controller.
4. Replace the system controller.
Hope that helps!
May 30, 2011 | Canon BJ-W9000 Copier
Photos are printing with too much blue un them. I have changed the color cartridge, cleaned print heads, etc. I am using only Epson namebrand products. Is there any adjustments I can make to correct this?...
It sounds like the print head may be clogged. To clean print head:
  1. Get a saucer and fill it with hot water
  2. Dip the print head in for 30 minutes
  3. Wipe the print head with a dry cloth
  4. Repeat the above at least 3-4 times (replace the hot water in the saucer each time)
  5. After repeating and wiping down the print head, put it back in your printer, put the cartridges in and run the print head cleaning function 2-3 times.
If it still doesn't work, then you may have to replace the print head.
May 10, 2011 | Epson Stylus Photo R280 Series
Cyan ink worked until needed to replace that empty cartridge. Now, all colors print but Cyan. I have cleaned inks, blocked eye with tape, cleaned where cartridge goes with warm water (in those holes),...
First do not use cartrigde compatible or refill because you clogged the print head,is verry sensitive.If you try to clean the print head and nothing you need to replace the print head is the only solution,after replace the print head you print all the colors.
NOTE!!! After you replace the print head use only original cartridge brother !!!!
Apr 07, 2011 | Brother MFC-230c Printer
HP Designjet 500, I have replaced the black print head twice, the first new print head would align and then fail the color calibration, the second new head aligns and pass's color calibration, but when I...
it seems there r some air in ur ink tube *** inser the priming heads & done the priming & reinstall the print heads if problem not resolved replace the carridge assembly,,,,,,,,,
Jun 03, 2010 | HP DesignJet 500ps (42 in.) InkJet Printer
Problem with black print head only.
clean by injection siringe, if not solved you need to replace print head
Jan 07, 2010 | Epson Stylus Photo R300 InkJet Printer
Resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Oct 23, 2009 | Canon BJC S300 InkJet Printer
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
HP OfficeJet 7310 All-In-One InkJet Printer Logo
48 people viewed this question
Clive
Clive
Thomas F. Schneider
