Question about Kenmore 22642 Top Load Washer
We just moved, and hooked up our Kenmore washing machine. On it's first cycle, during the end of the rinse cycle, it starts violently shaking and making loud noise. Any idea how we can trouble shoot this? The water connection is fine, no leaking, shaking also occurs when load is reduced.
  • 5,911 Answers
Since you mentioned you just moved, did you have shipping bolts installed on your washer? If the bolts are still installed, the washer will shake violently as soon as it begins to spin.
Also make sure the washer is level front-to-back and side-to-side. The back feet of the washer are auto-leveling. All you have to do is rock the washer forward, lifting the back feet off the floor (make sure the washer is empty when you do this). You will hear a clicking sound as the back feet readjust. Carefuly lower the washer back down to the floor and then level the front feet with the back by adjust them with a wrench. If you have questions, please let me know. I hope this helps you.
Posted on Jul 07, 2009
  • 31 Answers
Try and set your feet on the frount of the washer if the floor is oneven the washer will move about
Posted on Jun 28, 2009
Front loading machine shakes violently during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
The washer shakes violently during rinse/spin cycle, Probably from loading too heavy of a load,what can i do?
take out the heviest object put it back in evenly by it self .or cold be broken stabilizer spring.cold be laying inside the botum of machine.adjust legs.
Jan 25, 2010 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore he2 washer shakes violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Sounds like an airplane taking off!
check your drive block under your agitator if metal shavings replace
Nov 08, 2008 | Kenmore 22422 Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Violently shaking and noisy washing machine
I'm assuming you balanced this when you got it, right?
Mar 10, 2008 | Washing Machines
Kenmore washer shakes violently during spin cycle
syrny,
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
Nov 26, 2007 | Kenmore 22422 Top Load Washer
Kenmore 22642 Top Load Washer Logo
319 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
