Question about HP Pavilion a705w PC Desktop
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
  • 113 Answers
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Posted on Jun 28, 2009
    Problem Solver:
  • 8 Answers
IDE is the old bus. Most older computers and even the new ones may have an IDE bus. It is flat and long. The cable looks like a wide ribbon. The new ones are SATA. These are thin cables much like the USB. The connectors also look different. If you have a newer PC, most likely it is SATA. Try to keep SATA hard drives and leave IDE for a CDROM or something. It is about reusing what you have before getting new ones. So, the newer SATA is preferred. Open up the cover and look; or check the specs on your computer model. For example, I have 4 SATA ports and one IDE. I still use my old IDE hard drive and IDE CDROM. When I got a new DVD writer, I got a SATA one. Lately I also bought a 1 TB SATA hard drive. I did not remove old hard drive and CD. I have enough slots to keep them all.
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
I replaced an old CD/DVD R/W drive with an LG GH22N550 22X Internal SATA Super Multi DVD drive. The old drive was an IDE, I believe. After installing the new drive, the system wouldn't boot. It kept...
Look on the back of the old drive to check the jumper settings (master/slave) and set the new drive exactly the same. If that doesn't work, you may have to connect the drive to a different IDE connection on the motherboard... Also, check the BIOS settings for your IDE drives and make sure the one for the CD is set to AUTO or CD-ROM.
Oct 25, 2010 | LG CD/DVD-ROM Drives (DRGDR8163BI) Burner
I need a new IDE ribbon cable to install a new CD-RW/DVD and am looking for the type of connection to buy and a source from which to purchase.
Go to any small (or large) computer-store, and ask for an 80-pin IDE cable. Probably not more than $5.
Or, try a local "thrift store", and browse through their "electronics" stuff.
Or, find a computer "hoarder" -- they will have piles of cables, to give away.
Sep 17, 2010 | IBM ThinkPad (22P9163OB) (22P9163-OB)...
I am replacing my cd player/burner with a DVD writer model sh-s223 the attachments don't match what do I need to purchase
The sh-s223 is a SATA interface, you must have the older IDE/PATA type drive interface, this needs the wider IDE ribbon cable for data and a 4 pin MOLEX power plug.
You have bought the wrong DVD burner
You have 2 options
Return the drive and buy an IDE model... OR
Buy a sata expansion card, these can be bought for under £10
http://www.amazon.co.uk/Port-Expansion-VIA-VT6421a-chipset/dp/B000S87GG0
Jul 31, 2010 | Computers & Internet
Problem for Dell PowerEdge 2450 Server CD/DVD ROM
Its doubtful that its the cables. Can you tell me what type of DVD/CD you have? For example SATA or IDE. Look at the picture below, these are hard drives but the connections on the optical drives are the same>>>>>
If the interface is IDE then check the jumper settings if they are both on the same cable.
Also check another CD/DVD in the drives.
Let me know how you get on.
Regards.
Jul 01, 2010 | Computers & Internet
I think I have worn out my LG GSA-H42N CD/DVD burner (internal). Could you tell me what a good replacement would be? I purchased a Sony model but the connections for my PC are wrong. The PC is an MDG with...
Hi, as your LG GSA-H42N CD/DVD had an IDE interface you need a drive with the same type of interface .I had to replace my internal drive after years of use.As it was a Pioneer brand with an IDE interface I replaced it with a Pioneer DVR-A 18 L which cost £17.99.from Amazon.co.uk and that included free postage.
Regards Bill
Mar 26, 2010 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Dec 30, 2009 | Dell Dimension 3000® Pentium® 4...
How do i install a second writable disk drive???
aloha...this can be done, IF your computer has the expansion capacity. what kind of computer are you using?
Mar 17, 2008 | AOpen : CDRW 52x32x52 Beige Color Retail...
New DVD/CD Writer is not recognized
Try the drive in another machine to isolate the problem. If the drive works and its your system you may have to do the following Update your BIOS Place the drive on the other IDE channel. If there is only one IDE channel on your system board it sounds like you already have the jumpers set properly. If this is an older system you may only have a 40 pin cable, make sure you have a new IDE cable. The cable may also be damaged. Check the power to the drive. If none of that works and it is working but absolutly not compatable with your hardware you could purchase an external enclosure for it and connect it with the USB or Firewire. Hack
Jul 09, 2007 | Pioneer DVR-710 DVD±RW Dual Layer Burner
Acer T690 dvd not recognized
is this an ide drive? have you look for the jumper, single drive on one ide have no problem, but for two drives, one must be slave and the other a master. configuring your ide connections may fixed the problem.
May 20, 2007 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
HP Pavilion a705w PC Desktop Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
