Question about LG RC897T DVD Recorder/VCR Combo
Do i need an A/B switch along with my splitter in order to record from my digital cable box to my dvd/vcr combo?
  • powernpeace Jun 28, 2009
    thank you for your help, but I should've been more specific. I don't mind watching what I'm recording, but I having problems even doing that because I don't really know the wiring configuration. Can you help? I have a dvd/vcr combo, digital cable box, and a 42" toshiba hdtv
  • 69 Answers
Only if you want to watch something outher
then what your rec.
Posted on Jun 28, 2009
  • Robert Sheehan
    Robert Sheehan Jun 28, 2009
    sure
    ant to converter
    converter out to vcr ant in
    vcr out to tv ant Easy
I have a sanyo dvd player/video cassette recorder manufactured June 2003. what do I need to be able to record tv to vcr on my flat screen HDMI tv
Wall outlet <--- coax cable --> 1-to-2-splitter <-- coax cable --> Personal Digital Video Recorder <-- HDMI cable --> TV
and:
1-to-2-splitter <-- coax cable --> VCR
May 21, 2014 | Sanyo DVW-6100 DVD Player/VCR
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
I am unable to get my vcr to record. To use my vcr i have to turn my tv to channel 3. Our cable company uses channel 4. Please help
If the tv is working with the cable box with the coax to channel 4 ( then with this configuration to send any signal to the VCR actually it is posible to use a splitter with coax and send the signal to the tv and vcr after the cable box. vcr has tobe in channel 4 also, all channel selection is done in the cable box then anything you see in the tv is recorded in vcr. BUT guess what: You maybe can try something else:
If you send the cable from the wall straight to the splitter and then from splitter to the TV and to VCR, now you can record differnt channel than you are watching in the tv but in this case scenario you need to send the vcr to the video input 1 of the tv to play what is record. Any way to install this TV and VCR you not always need to depend in the cable box.
May 01, 2009 | Sanyo DVW-7000 DVD Player/VCR
I have an insignia dvd/vcr combo. how do u record vhs with a cable box
Try a splitter on the main cable line.One line to the cable box the other to the vcr.
Dec 31, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
SETUP ADVICE NEEDED TO INTERFACE WITH MOTOROLA DCH 70 CABLE TUNER
Take a splitter from the wall and plug it in using a seperate line. You wont get all the digital channels but you can get channels up to 150 to record. Depending on how many av outputs you have on the back of your digital tuner you might be able to take one of those those and plug it into the av input of your DVD recorder. You can get a better picture that way when you record from the cable box vs using coax.
Make sure the splitter is approved for digital cable use. The Radio Shack ones work the best and they are usually the same version of the ones Comcast sells to customers. If you get a brand like they carry at drug stores you will lose picture quality and probably end up with a service call bill as well.
Aug 04, 2008 | RCA DRC8320 DVD Recorder/VCR
Digital to analog converter box to tv/vcr combo
You will need a splitter and an rf modulator to do timed recording of programs. The instructions are on the dtv answers website, option # 2, record and watch a different channel. The recording is for the analog stations 1-24. You cannot record the higher stations. The items I purchased were a 3 way splitter $7 at local hardware store, an rf modulator $25 at Radio Shack. The other option was to get a cable box for the tv and record off of that at $6.95 a month or a DVR for $8.99 per month, all from comcast. The price that I paid for the items I needed would be repaid in 3 months if I were to go the comcast route. The conversion is nothing more than a money making scheme for them.
Mar 21, 2008 | Televison & Video
CONNNECTING THE DMR-EZ475V TO A TV, THEATRE SYSTEM AND CABLE BOX
noavatar_s.png jdrrwoods
Rank:wizard_s.gif Wiz
Rating: 84%, 12 votes
http://www.altex.com/product_info.php?products_id=9207 here is a link to a audio / video switch box you need one of these make sure it has several audio video in and at least one audio/video out
hook all you rca1.gif cables up to the audio/video in from the cable box, tv, and dvd/vcr combo then out to the surround sound youll also need to get some rca cable splitters for the out so you can run it back to the audio/video in to the tv as well as the surround sound here is alink to what they look like
http://www.altex.com/product_info.php?cPath=344&products_id=6201
youll need thre of these of course when hooking it up dont pay attention to the color on these just the ones from the tv and surround sound and thats it your done it will all work if you want it to were you dont have to get up and push a button everytime most of them if you push all the buttons in at one time theyll stay like that
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
LG RC897T DVD Recorder/VCR Combo Logo
172 people viewed this question
