Question about Coffee Makers & Espresso Machines
MY SENSEO COFFEE MAKER KEEPS FLASHING LIKE IT HAS NO WATER EVEN WHEN THE CONTAINER IS FULL.
    Problem Solver:
  • 7 Answers
Try making the coffee when the waters empty it tastes great!
Posted on Jun 28, 2009
THE RED BUTTON FLASHES RAPIDLY
I guess it's the metal part in the water tank that makes contact with the machine when the water runs out. When you take the water tank off the Senseo it's in the bottom right corner. If you can't repair it, a spare water tank isn't that expensive.
Jun 20, 2014 | Philips Senseo HD-7810 Coffee Maker
Water stored inside unit
put unit upside down, for a longer period, or, get the container filled with water, or water and vinegar, and let it run a few times.
Pushing both one + two cup buttons should make it run at once, do get a large container under it
Jan 26, 2014 | Philips Senseo HD-7810 Coffee Maker
On light will not stop blinking on my Senseo coffee machine
my senseo did the same. i read on hear to clean magnet/float mechanism inside the water resevoir. i did this with a tooth-brush and soapy water. as you invert the empty water container you will see/hear the float slide up and down when clean. work a treat for me.
Nov 20, 2012 | Philips Senseo HD-7810 Coffee Maker
The add water light keeps flashing when the container is full of water
The float on the side of the container is stuck in the down position, giving the machine a false reading of the water level... get the float, floating again...
heatman101
Aug 20, 2011 | Keurig B60 Coffee Maker
I live in a limestone area and the flow through my Senseo coffee maker is slowly reducing. How should I descale it?
Believe it or not, vinegar is a blessing for cleaning nearly anything out of your coffee maker.
Fill your water reservoir 1/4th full with vinegar, then fill it the rest of the way up with water.
Run the coffee maker, then let it sit for about 10 minutes. Pour the mixture back in to the reservoir and run it again. Let it sit another 10 minutes.
Dump the mixture and use plain water this time. Let it sit for another 10 minutes. Dump the water, then repeat with clean plain water.
Wash the filter basket and pot with hot soapy water. If the vinegar smell is still present, just run it again with plain clean water.
Oct 10, 2009 | Philips Senseo HD-7810 Coffee Maker
Light keeps flashing and water will not heat
there is a float at the side of the machine by the water level, if the float gets stuck the red light will continue to flash even though water is present. Use a magnet on the outside of the machine by the water and float level and raise the float when connected to the magnet and the light will stop flashing red rapidly
Oct 05, 2009 | Philips Senseo HD7832 Coffee Maker
Senseo 7814 does not heat water and red light keeps flashing
is the red light flashing as though not enough water, if so use a magnet to connect to the valve inside the machine, the valve can be found along the water level where the float is. what is happening is that the float is stuck. by connecting the magnet to the valve and very slowly moving the magnet along the water level, upwards the valve will follow and the water will begin to heat as the light changes to a slow flash, if it doesn't work try again as you have not connected to the magnet
Aug 26, 2009 | Philips Senseo HD7832 Coffee Maker
Coffee comes out as weak as coloured water! far too weak.
you probably are not putting enough coffee in to strengthen the coffee
Apr 25, 2009 | Philips Senseo HD-7810 Coffee Maker
The water is not heating up!
Makesure the water holder is seated right. also follow the directions toclean it out once.
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Feb 01, 2009 | Philips Senseo HD-7810 Coffee Maker
Coffee Makers & Espresso Machines Logo
154 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
