Question about Canon PIXMA MP530 All-In-One InkJet Printer
Black lines appear on copies made from top feeder but not from glass top.
    Scholar:
  • 103 Answers
Check the paper path from top feeder. Sometimes is a transparent plastic film need to be replace cause a scratch and sometimes is dirt or other obstruction like dust or liquid paper still not dry when scanned a paper and get clogged.
Posted on Jun 28, 2009
I am getting a black line on scanned documents of my HP Officejet 6310 All-in-One Thanks
It would require you to open scanner and clean scanning head unfortunately.
Aug 02, 2015 | HP Office Equipment & Supplies
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
HP 3030 ALL IN ONE. WHEN COPYING OR FAXING FROM TOP FEEDER A FULL LENGTH VERTICAL BLACK LINE APPEARS. WHEN COPYING FROM GLASS OR SENT FROM COMPUTER NO BLACK LINE.
Clean the ADF glass. That's the skinny glass strip at the left of the flat bed glass. There is a speck of dirt on it. Line the black line up with the glass, to get a general idea of where to clean. Damp lint free cloth
Aug 01, 2011 | HP LaserJet 3030 All-In-One Printer
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
When trying to make copies from the Cannon Imagerunner 3230 machine, we keep getting a black line on top of the copies. I tried cleaning the inside but it still appears. What could that be?
Drum Unit, Make sure the scan glass and platen glass is clean. Run copies from glass and document feeder to see if line appears on one or both. Both Drum unit or fusing Film. Will need a copier tech to remove parts for inspection.
Jun 09, 2010 | Canon imageRUNNER 3230 Black and White...
Line in copies that go thru feeder
Over time the automatic document feeder (ADF) will get dirty, occasionally causing vertical black streaks or lines in scans and copies .
Manual cleaning of the ADF might be necessary. Follow the procedure below to manually clean the ADF .
You will need the following materials:
  • Soft lint-free cloths
  • Glass cleaner
if you look carefully on the left side of ADF ( top feeder ) there is an assembly which u can lift , there wud be a set of rollers if u lift that part there would be a glass strip . u are suppose to clean that strip .
While holding up the inside of the ADF, clean the glass in the location of the vertical streak with one of the cotton swabs. Try cleaning the glass first with a dry cotton swab. If that does not correct the problem, then moisten the swab with glass cleaner .
If the vertical lines or streaks still appear, go through the above cleaning process again, this time cleaning the entire surface of the ADF scanner glass.
and after this try the following steps as well .
CAUTION: Use only glass cleaner. Avoid abrasives, acetone, benzene, and carbon tetrachloride, all of which can damage the scanner glass.
Apr 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Black line on copies
If your copier has an automatic feeder and your line is present when using the feeder but not when you copy from the glass,just clean the small glass at the point where the line appears.
Feb 28, 2008 | Canon ImageClass D880 Copier
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Problem while copying
O.K. guys,
the problem is with the smaller glass on the left.
Lift the top and look at the small glass on the left, is there a dot, whiteout, dirt etc... on there? that is what's making your lines. clean with alcohol or mild cleanser.
Nov 07, 2007 | Kyocera RI-3530 Black and White Copier
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
130 people viewed this question
old marine
old marine
