Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door won't shut, light blinks 10 times.
The door closes a couple of inches, then stops and the light blinks 10 times. Both sensors are green. HELP!
    President:
  • 3,197 Answers
If the light blinks 10 times it is a sensor problem. Nothing else will cause this. Tweak the sensor a bit and check it out.
Posted on Jun 29, 2009
LiftMaster Pro 1/2 hp 41AS050-1 won't shut. when
Check the resistance down button (There is one for down and another one for up). You may need to adjust the sensitivity. That way even if for some reason the have hard time coming down, less sensitivity may solve that issue.
Oct 22, 2013 | Sears Craftsman LiftMaster Chamberlain...
Sensor problem with garage door opener. One of them has a yellow light the other a green. The door starts to close than stops. You can close it if you hold the button down inside and the remothe doesn't...
If it moves 6-8 inches and then stops it is most likely the rpm sensor.
Yellow and green are what the lights should be.
Does the led on the wall control blink?? If is does press the lock button.
If it doesn't you will need to reprogram the remote.
Watch the eyes as the door closes, does one of them go off? If so the track may be flexing causing misalignment. (Widen the track near the bottom)
If all of the above don't help check the sensitivity adjustment. Turn it about 1/8 turn clockwise and try the door again - continue this until the door goes full cycle without reversing. If you have to set the sensitivity past 3/4 the door needs to be adjusted.
Jul 20, 2010 | liftmaster Chamberlain Garage Door Opener...
CRFATSMAN opener - Problem when closing only
It sounds like you have a loose connection. Pull the logic board and check for bad connections especially around the small transformer.
Feb 23, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener won't close. travels 6-8 in.,
If you cannot get the light on the sensor to come on by tweaking it,making sure it is pointed at the other sensor and your wiring is not broken or shorted then your sensors need to be replaced.
Jan 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
Both lights on our garage door sensors are green (not blinking), but the door will not close with the remote or button in the garage. It does close if you force it by holding down the button in the garage....
If the main light flashes 10 times when the door starts to close and then reverses it is a door sensor problem. Look very closely at the lights on the sensors. If one of them is flickering ever so slightly it will give you the problem you have.
If the main light is not flashing then you need to increase the down force which is near where all those white wires go. A 1/4 turn should do it.
Nov 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens, when closing stops immediately but there is nothing blocking the safety light and lights are green. I can hold the button and door will close but as soon as i release the button it opens again.
Check your door sensors closely. Sometimes one will be off just a bit and the light will be on but blinking ever so slightly. If the main light flashes 10 times when the door reverses it is definitely a door sensor problem. Nothing else will cause that.
Nov 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
When i try to close garage with transmitter or keypad it moves a few inches and stops or goes back up
If the main light flashes 10 times when the door reverses it is a door sensor problem. Make sure the small light on each sensor is lit and not blinking. The sensors must be pointed at one another to work properly. If you cannot get both lights to come on you have a bad sensor.
Oct 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Mine does the same thing...
If the main light is flashing 10 times you have a door sensor problem. Might be the wiring to the sensors. Nothing else will cause this flashing of the main light.
Jul 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO reverses itself when the door reaches the eyes
The only thing that will cause the main light to blink 10 times is a sensor problem. Sometimes the sensors will be misaligned just enough to turn the light on but will not work properly. If you look really close (on your knees) you can see the receiving sensor blinking ever so slightly. Tweak the sensors until the light glows constant.
Jun 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
10,078 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
