Question about Compaq Presario M2000 Notebook
A fine blue line has appeared down the side of the screen any ideas
  • Compaq Master
  • 32,281 Answers
To determine if you have a provlem with the LCD screen or the video card, connect an external monitor to the laptop's video port and power up the monitor first and then the laptop. The video will divert automatically to the external monitor. If you get a normal Windows image on the monitor then the fault is with the LCD screen, if not then the fault is a faulty video card.
Get back to me with the results of this test.
Posted on Jun 28, 2009
How do I fix a Samsung un55c8000xfxza that has been through a fire? The TV still operates fine but the screen is dark on one side and has vertical lines on one side.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 30, 2016 | Samsung Televison & Video
Why appear blue and black lines on my tv screen?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Feb 11, 2015 | LG Televison & Video
New lcd installed in satellite l505, started out fine, as it warmed up a single vertical line appeared about 3 in from left, will occasionally disappear, but comes back in same spot after a few minutes,...
Yes, this unfortunately is the beginning of the end of the LCD screen, you see the "Driver Circuit Transistors" are starting to go faulty... this is a very common problem, occasionally, it may be the Video card, you will have to "monitor"...(pun intended), the situation. If it continues, as I expect, and lines appear down across, the screen that never go away, and are RED or BLUE or GREEN, then it is most definitely the LCD itself, if however they go away come back in differing places, then it is more likely the Video card. replacement is the only fix sorry. I would wait until it is unbearable before you do anything.
Feb 23, 2010 | Computers & Internet
Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Jun 12, 2009 | Sanyo Televison & Video
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
Vertical lines appear on screen...
You have a defective light engine. Contact RCA support. Sometimes they will warranty these even after the 1yr warranty has expired.
May 16, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Blue line down right hand side of screen
If you are confident enough to open screen bezel and take out screen , then the second strap from right of your screen has a bad connection. theses cannot be repaired but as a tempory measure some duct tape across the connections will cure it, else replace the screen.
Mar 16, 2009 | Acer Aspire 9500 Notebook
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
LCD TV - Vertical Blue line
My Lcd monitor has blue line? How can I solve this problem?
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
use menu and h/v then change then move to higher level and it will take it away.
Oct 09, 2007 | Vizio Gallevia GV42LF 42 in. LCD...
Compaq Presario M2000 Notebook Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
