Question about Sanyo HT30744 TV
Green screen My 30" Sanyo HT30744 periodically goes green. Sometimes I can turn it off and on and it goes back to normal colours but sometimes not. What is the solution?
  • 1 more comment
  • Go Ahead Dec 18, 2007
    I have had it for 3 years & the screen is getting greener & greener! Please help
  • SXcalibur Aug 31, 2008
    I have the same problem,it gets really bad green and sometimes takes a long time to return to normal.
  • snokly Dec 12, 2008
    what is goiong on with my tv its getin green
  • 4 Answers
Open it up and check to see it the circuit board attached to the tube is seated all the way down. Both of mine were not attached that well so I pushed them back down and have not had any problems since.
Posted on Mar 03, 2009
  • 3 Answers
Open it up (remove the 8 or 10 screws) and clean the dust (by compressed air or vacuum cleaner hose) off the circuit board. It fixed mine like a charm! A dust buildup creates a short across the closely spaced circuits and disrupts your picture. You may need to do this every few years, especially in dusty environments. Works for computer motherboards and power supplies too! You have nothing to lose, and it's very easy. Just be gentle with the circuit board.
Posted on Feb 12, 2011
It's a known problem covered by Sanyo, even out of warranty sets... call them
Posted on Feb 06, 2008
Junk it got it two years ago and did same thing won't repair the red bulb is going out
Posted on Nov 19, 2007
Picture turns green ,usually within 10 minutes of turning it on.It will sometimes go back to normal color but generally returns to green.This happened when the set was much newer and Sony replaced all...
Green Tube maybe trying to short out or you can try adjusting screen drive to the Green Tube by turning control down a notch, Sony had a bad run on these with alot of Bad Tubes.
Dec 08, 2009 | Sony KP-57HW40 57" Rear Projection...
My 32" sanyo picture goes green
needs resoldering, in the heated areas, such as, crt socket board, power area, and high voltage area....it will be back to normal...
Oct 20, 2009 | Sanyo DS32920 32" TV
Sanyo xacti digital camcorder screen not working when opened out
Hi!
It's most likely a damaged LCD cable which goes through the hinge - happens to many camcorders. You will have to contact your local Sanyo service center. I replace these cables for Sony camcorders every day.
Sorry for the bad news, but hope this helps.
Tom
Sep 27, 2009 | Sanyo Xacti E1 Waterproof Camcorder
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Green screen
Not really sure how much the tv weighs, but I know it is a bunch. I have 2 of these t.v.s. One I bought at Wal-mart and after about 6 months it started doing this green screen also. I would normally give the side of the tv a good wack and it would go back to normal for awhile. The other tv I bought from my neighbor who was moving for $25. The problem with this one was the "no picture but I have sound". If I wacked this one I could get the picture to come back on for a while, but it would go out again. Well just the other day I took the back off the "no picture" tv and was looking around. I noticed that the circuit board that is attached to the picture tube was loose. I pushed it back down on the tube and put it back together and the picture has been fine since. So I thought I would check the one with "green screen" issues and sure enough that circuit board was loose also. Pushed that one all the way back down and have not had any issues with that tv either. Hopefully that fixed my problem, I guess time will tell. Maybe it will fix yours also.
May 19, 2008 | Sanyo HT30744 TV
Black pic on tv turns green
normally this means the high voltage preamp green control transistor on the neck of the tube circuit board is loose solder connection from heat or is going bad.
Feb 17, 2008 | Sanyo HT32744 32" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Color Turns Green
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
May 13, 2007 | Sharp 27H-S60 TV
Open Questions:
Sanyo HT30744 TV Logo
671 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
