Question about Kenmore Washing Machines
Top of AGITATOR NOT TURNING. Buttom turns fine.
  • Kenmore Master
  • 3,361 Answers
Replace the agitator dogs in the top of the agitator.$5 part.
Posted on Jun 28, 2009
Will not turn on.battery tested and was fine.
Bad push buttom, or something inside the buttom, like any cola or kool aid between the push buttom.
Try to check if the push power buttom it´s working.
Dec 07, 2015 | Cameras
My Sear Kenmore washing macbine will barely agitate when using the full size load. It barely moves, but on small or medium loads it works fine. What seems to be my problem?\r\nModel #110.26292692 SN#...
Take and turn the agitator by hand. It should only turn one way. If the agitator will turn freely either way, then you will need to replace the "agitator dogs" that go in the top of the agitator. Take a look at this video.
Jul 21, 2011 | Kenmore 16812 Washer
The agitator (upper portion) will not spin. If I
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following illustrated description of the above.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=0da65cea0e338fe930b1fde153a243f0
Mar 02, 2010 | Kenmore 22422 Top Load Washer
Agitator: bottom moves, top does not
On the Sears parts site:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691&pop=flush
replace the 110.26902691 with your model number (lift the lid and the model number should be printed on the cabinet) and look at the section on the Sears site for Agitator, basket and tub.
This is what they look like:
pd_26_110_80040?$pddetailsth$ #21 on diagram Dog, agitator (4) Number:3366877Substitution:80040 $9.25Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Sep 13, 2009 | Kenmore 23822 Top Load Washer
Top half of agitator turns free (does not agitate)
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Feb 25, 2009 | Washing Machines
Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2009 | Whirlpool WTW5800SW
Top of agitator not agitating
This is a problem with the parts that we called dog agitator. They are 4 pcs plastic parts that function as a lock on a ratchet handle drive.
the top agitator would turn one way and these dog agitators prevents it from going the other way.
To replace it, you have to remove the top softener dispenser, remove another plastic cover that covers the bolt from water. remove the bolt and you can pull the whole agitator out of the tub.
Be careful on dismantling, it is tricky to put it back. Remember where every part goes.
Tnx for using Fixya,
drcool
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Top part of agitator won't agitator
You all have a problem with a part called agitator dog.. 4 little hard rubber like pieces that goes in the top agitator.. and yes washing blankets or overload can cause this..pop top cap and you will see a bolt that holds the agitator..remove that and take out agitator.. and replace agitator dogs ( comes in a pack of 4).. make sure they all face same direction... good luck..
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't agitate and makes a grinding noise
hi thanks for the question yes it is a bad transmission sorry
Sep 25, 2008 | Maytag PAV2300 Top Load Washer
Roper RAX4232KQ - Top part of agitator won't turn
you need to install new agitator dogs . very in expensive. remove cap on top of agitator reach in and remove opaque cover. you should see a 1/2 " bolt remove that and pull up on agitator. pull apart two halves. disassemble. install four dogs. reassemble in reverse order
Feb 06, 2008 | Roper RAX4232KQ Top Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
