Question about Motorola Walkie Talkie 2-Way Radio
Motorola EM1000 2 way talkie unable to transmit
I having a set of 3. And 1 of them having problem to transmit to 2 set, under the same frequency and channels.
This faulty set beep 2 times, after I push down the PPT. The other 2 working set will not have such beeping sound, and they are able to transmit to each.
Why is the talkie reacting these way? It is really time for servicing?
  • edgarchen Jun 29, 2009
    I had all the 3 sets batteries charged fully.. Now that the beeping sound for the faulty set is resolved, but the faulty set is still unable to transmit nor receive any signal, under the same frequency and channels.. from the other 2 working set..
    Is there any other reason to have it malfunction?
    No, the QT noise filtering is on & off function on the faulty set has no effect in getting the transmission across to and receiving from the other 2 working sets.
  • Motorola Master
  • 1,654 Answers
Low/Bad battery beep most likely. Try switching batteries to the problem radio and see if the problem goes away. If so, replace the batteries. You might also check the battery contacts both in/on the radio and the battery. Clean with a pencil eraser if necessary.
Posted on Jun 28, 2009
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
Jan 20, 2015 | Generic Walkie Talkie BAOFENG BF-888s Two...
What does Mon mean on a walkie talkie?
"Mon" is short for "Monitor" and is usually a feature that allows you to momentarily break the squelch (signal filter) and hear anything being transmitted on that frequency. That includes static if there's no transmissions. It allows you to listen for a weak signal that can't break the squelch threshold you have set. Some radios allow you to lock it open by pressing and holding the MON button for a few seconds. Turn the feature off my doing the same thing.
Jul 03, 2014 | Motorola Walkie Talkies 23-mile Range...
Both walkie talkies are on the same channel, but will not transmit voice messages
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 05, 2014 | Motorola Walkie Talkie 2-Way Radio
I have a t5500 that will no longer transmit or recieve with any of my other motorola walkie talkies. any ideas
Check the settings of the Frequency, Code and Qt filter on your non-functioning radio vs. the working ones. They all should match identically. Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Dec 28, 2009 | Motorola Walkie Talkies 2-Way Radio
They work close up but not far away
Double check the frequency you have the radios set to, and be certain they are exact. Sometimes when you are on a near frequency you will have range problems. Also, hold the radio upright with the antenna pointed straight up when transmitting. Face the direction you are trying to transmit. Height and placement of the antenna determines range. Handhelds can generally talk as far as they can see. Obstacles between you and the other radio can reduce range, including the body fluid of the person wearing the radio. And lastly, be certain you are using good batteries for best performance.
Best regards.
Dec 18, 2009 | Motorola Walkie Talkie 2-Way Radio
T5420 unable to transmit or receive. Please help!
Here is a link to the user manual: http://www.giantintl.com/ContentManage/manuals/Moto/T5320_T5410_T5420_User_Manual_E.pdf
This unit does not have a reset button. While troubleshooting you might check the batteries. Be certain they are in correctly and the contacts are free of corrosion. You can use a pencil eraser to clean the contacts.
Walk through all the programming instructions in the manual, double checking both the frequency and interference eliminator codes. A quick setting back to zero on the code would alleviate any problem with that section of the radio.
As far as your "paging" this operates on the same frequency and code as the rest of the radio. If the radios are not working correctly in this relm, the paging will not work either.
Apr 24, 2009 | Motorola TalkAbout T5000 2-Way Radio
Strange sound coming from walkie talkie, strange beeping
Most Motorola radios give a beep-beep when the batteries are low and need changing. Make sure to use a good brand of battery. One other thing to check for is leaking batteries, the crud with cut down on performance.
Oct 20, 2008 | Motorola Walkie Talkie 2-Way Radio
Motorola T5420 Transmit Problem
Here are some troubleshooting thoughts:
1. Is your battery indicator showing at least 2-3 bars? (Battery Note: Your rechargeable batteries may fail due to setting without use for a long period of time. They need replaced every 12-14 months usually. A good tip is to charge them once a month to keep the chemical in the battery active.)
2. Check to see your Qt noise filter is shut off. Refer to page 22 of the owners manual. It is possible you have some radios set to Y and others to N. To assure good communications you should set all of them to N.
3. With your radios set to interference code zero, place your radios one at a time in scan mode, while you transmit/talk on one individual radio. See if any of the radios receive. Do this with each radio individually to see if you are transmitting at all. NOTE: This test will determine if you have any ability to transmit. If you do not receive any sound on the 3 radios setting in scan mode, the individual radio you are testing will not transmit.
Aug 25, 2008 | Motorola Talkabout T5420 (14 Channels)...
Here is a link to the T5000-T5500 user manual. 'http://www.motorola.com/mdirect/manuals/T50-T55_UserGuide.pdf'
From what you have stated, I can discern the radios will power up. You might try setting your interference eliminators to zero (off) to see if you are able to transmit at all.
You do not mention if you are using AA batteries or rechargeables. Either way a fresh set of charged batteries would be best for a test. It is clear you were getting power. However, it does take more energy to transmit than to receive. If your batteries are low or bad, pressing the PTT could us all the energy the radio has, and yet not transmit to the other units.
You might also check you VOX settings if any and be certain they are turned off.
It is not likely 4 radios would fail all at the same time. So it is probably a programming problem. Hope the user manual helps you find the solution.
Aug 23, 2008 | Motorola Talkabout T5420 (14 Channels)...
Radio Communications Logo
820 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
