Question about HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard
When power on my laptop it is not working?
My laptop model is hp pavillion dv6241eu ,when I press the power button
the power leds are on and gets down withing a few seconds .
I removed the battery and directly connected to power ,the samething is happening? I know the battery and power adoptor is working well.
But I dont know the problem. I have recently replaced the hard drive three months before.
  • 788 Answers
Ok, you say when you power up the unit, the power Led comes up an then goes out.?
1st. If you have the battery inserted and the power adapter plugged in and the charging light comes on, showing the battery is charging, the power adapter and battery are most likely OK.
That's not the problem.
2nd. If the unit tries to power up and fails, the best thing you can do is, A. Remove any media in CD/DVD drive. Reove the power adapter and battery,
B. Remove the two covers showing the Hard Drive and Memory. Remove Both H/D and Memory.
C. Disconnect the CMOS Battery, located just above and top right of memory. (Next to Wireless Card). The is a white 2-pin connector.
D. Flip the unit over and press the power button for 15-30 seconds.
3rd. Know you have cleared the CMOS. You will have to re-enter the time and date, once the unit comes back on line.
4th. Reinstall only one piece of memory, Then the CMOS battery and leave the cover off for now.
5ft. Install the battery, Flip the unit over and plug in the A/C adapter.
6st. Look to see if the charging light comes on.
7th. If the charge light comes up, Power up the unit.
The message you should see is Date and Time press F-10 to continue. and then should say, missing Operating system or no disk found.
Remember if the unit will enter the BIOS screen and does not drop off, your in good shape.!
Power off the unit.
8th. Re-install remaining memory and check again. If no problems,
9th. Turn unit off and re-install Hard Drive.
10th. Power on unit and if you have problems, OK., more than likely, its the H/D. and may need to be re-formatted.
If the unit comes up OK, and you suspect the hard drive is at fault, Look for the Hard Drive Test utility in the BIOS screen. (This will smart drive test the hard drive and will take some time, depending upon the size of the drive..)
If you have errors on the drive on the boot partition, you will know soon enough, being the drive has two partition, one in the front of drive and one at the end.
If the drive is OK good deal.
If after trying all the above and the unit still will not power up and run correctly, please respond to this info. and I will run you thru some other things to check.
People please respond to our reply's to for help. If you do not rate us, we are waisting our time to go into detail helping you.
If you feel this information has wasted your time, please call HP and you will come away feeling differently.
Hope this information has been of some kind of help.
Try it, it may work !!
John Ray
john@johnrraycomputer.com
Posted on Jun 29, 2009
  • 268 Answers
Power off the unit.
Bryan Madison Santiago
Posted on Oct 26, 2011
HP Pavillion dv4 turn on and the fan start for a second twice and then tunn off After around 5 seconds a few leds are blinking Hard Drive work fine on other laptop What can be the reason
Hello, that sounds a motherboard problem...
Try to do this first :
1- take the battery out and disconnect from power
2- press and hold the power button at least 10 seconds
then put only the power cable not the battery and try to boot...
If this dont help...your motherboard needs to be repaired or replaced.
Thanks.Please rate this answer
Jan 25, 2011 | HP Pavilion dv4-1120us Notebook
My hp pavillion dv6700 will not power up all of the blue lights will flicker as i press the power button for a few seconds then it will power off. ive tried taking the battery out and running it strictly...
Your DC jack may be loose or broken off the system board.
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it's still under warranty, it would be fixed at no charge to you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 19, 2011 | HP Pavilion dv6000z Notebook
My hp pavillion dv4-1220us laptop, won't start up...I press the power button and it turns on for a couple seconds and then turns back off....
1) Is it the battery, power up using the power supply.
2) When the power supply is plugged in, is there a charge light/led (could by a bad power supply not charging or providing a good connection)
3) Is the CPU over heating? Check the vents underneath are they clogged with dust?
After this, you're getting into internal faulty component issues and need someone to look at it.
Apr 13, 2010 | HP NB199UA Pavilion Notebook
Hp pavillion dv6700 does not power up
cpu is not getting the power coz the smps is not supplyin power to it so change ur smps or chk its wires
Aug 22, 2009 | HP ProCurve Switch 2650
Hp pavillion dv2000 laptop display problems
There is a known problem with the video card in this machine, certain models are covered by an extended HP warranty.  Symptoms are overheating and finally not starting at all.
See this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
May 03, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
My wirless is not working
The wireless switch is located just behind and to the left of the wireless LED. The wireless LED is located on the left of the bottom half of your laptop looking from the front between the battery, power and harddrive LED's and the audio jack sockets.
Aug 03, 2008 | HP Pavilion dv9000z Notebook
HP Pavillion ze1000 laptop will not power up
that could be one of many problems. bad power supply, loose power connector, zapped motherboard. that model as i recall, had those problems,
Feb 02, 2008 | Computers & Internet
HP pavillion ze4420us
press the reset button on the BOTTOM of the computer
Nov 19, 2007 | HP Pavilion ze4420us Notebook
HP 417035-001 - HP Pavilion dv2000 Series Laptop Full Featured Intel Chipset Motherboard  Logo
193 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
