Question about Sony PS-LX250 Turntable
The turntable won't turn off.
It appears the "on" button is jammed in, and the "off" button won't work. Both buttons feel sort of loose. My wife hit it with a tennis ball while playing with the dog.
  • 515 Answers
The ole' wife hit the turntable with a tennis ball while playing with the dog accident. Very familiar with it. You can try a couple of different things...
1) Go inside the turntable, and see if you can fix it. Often times, there is a spring or bearing underneath the button, which has come dislodge. Just a matter of getting in there and putting it back.
2) See if some electrical contact spray does the trick. This stuff works great. and it's also available at most Radio Shack's now.
3) Just unplug it when u want to turn it off. Although, this is not really recommended, as your unit will be prone to slight surges and sparks - unless you just connect it to a power surge protector with a switch on it.
If all else fails, bring it to a service location for assistance. Shouldn't cost too much to fix, unless... the switches underneath the buttons are broken and need to be replaced. The switches are inexpensive ($5-10 part), but they'll get you on labor.
Posted on Nov 14, 2007
T The turntable won't turn on.
Posted on May 11, 2009
A few years ago I purchased a Philco capital turntable CD cassette. One day my wife was listening and for some reason she pressed the standby button, ever since then nothing will work. The power does come...
maybe the button when being pressed isn't releasing through a bad button . it would make sense that when the button is pushed it stops all functions so if you r able to disconect the button from the wires tape the wires together to create a closed circuit and see if it works personally i would take it to a repair facility for the safety factor of messing around with it but if u want try it
Sep 26, 2013 | Philco 841205 Turntable
Blackberry 8520 won't reboot goes half way then stops took battery out left all night still won't go any further what can I do ? Please
my phone does this ever so often... you will lose all the data on the phone. with the phone off take the sdd card out and then while holding the volume button (+ or - changes from phone to phone... hold the volume camera and power button and wait for the screen you dont ever see, if you stop holding or hold the wrong volume button it will not work... then when that screen pops up hit your menu button on the touch screen, use the volume button to scroll down to system restore or what ever its called and select it with the camera button... then reboot your phone.
Feb 08, 2013 | Cell Phones
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
While my wife was washing, the water was turned off to the washer. She hit the pause/cancel button. Now that the water is turned back on, when we hit the start button, all the lights turn off.
Hello,Select any button except start and hold it 4 seconds let go 4sec hold 4sec let go 4sec hold 4sec see if unit goes in service mode all lights will come on hit same button again unit will go into aut test and run a cycle when its done unplug for 5 minutes plug back in and see if unit works.
Jun 18, 2011 | Maytag EPIC MFW9700S Front Load Washer
Camera keeps rewinding film
Check the manual rewind button on the bottom plate of the camera. Make sure the button is not jammed under the edge of the button opening. If it is you might be able to carefully pry it out with a sharp pin or tooth pick (be careful not to pierce the button or you could damage the circuit board underneath) Or you could remove the bottom plate and reseat the button (be careful of a loose spring to the film door latch)
Dec 03, 2008 | Minolta Maxxum 300si 35mm SLR Camera
Dryer drum won;t turn
you have a bad motor / sorry to tell you but thats what your looking at / larryyb
Nov 24, 2008 | Dryers
VS 7071
Do a hard reset or factory reset and it should work again
Dec 15, 2017 | Mitsubishi VS-70707 70" Rear Projection...
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
TECHNICS SL1200MK2 RPM Buttons getting stuck..
Ed try spraying some contact spray directly in to the Buttons,push one then the other you will feel them free up Please rate my performance ttech
Jul 21, 2007 | Technics SL-1200MK2 Turntable
Sony PS-LX250 Turntable Logo
260 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
