Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
NO WATER COMES OUT OF UPPER WASH ARMS - Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
    Genius:
  • 1,036 Answers
This is usually because of food items inside the arms.
Undo the top arm (clips or large screw) - and back-wash the arm through the spray holes..
This usually solves the problem.
Sometimes the clips wear that hold the arms on - if this is the case - buy a replacement spray arm.
Posted on Jun 28, 2009
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
My Kenmore Ultra Wash II fills with water but doesn't spray.
i would suspect water mains problem, not enough water getting to the machine sometimes inlet get clogged with lime.adrian,,,,
Jul 13, 2010 | Kenmore 17024 Built-in Dishwasher
Water not pumping through wash arms
It would be helpful to know the model no. of your dishwasher.
I few things to check
1. is the water getting into the unit - tap on etc.
2. are the spray arms free of debris - remove and clean the holes
3. do you hear the arms rotate when unit is turned on.
4. how do you know the water is not pumping through the arms
Hopefully we can diagnose the problem for you.
Jan 24, 2010 | Jenn-Air Dishwashers
My maytag mdb8600aws jet clean 2 only cleans dishes in bottom
The seals that the racks "plug" into need replaced. Ours had the same issue and replaced the seals and it works fine now.
Nov 23, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Sprayer arms not spinning
I know this sounds too simple, but on My dishwasher which is an SHX46b model, the plastic supply arm that comes out of the pump and supplies the upper arm popped out of it's correct position at the base. It is held in place by two dinky nibs. I just popped it back in and voila, pressure was back and arms were spinning.
Jul 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher has power and water but rinse arms are not working
Vicky,
I understand that your LDF8812 fills with water (and drains?) but is not cleaning and you are not hearing the unit wash. Are the dishes on either rack getting wet at all?
-Are you getting any error codes in the display?
On LG dishwashers, the upper and the lower arms never spin at the same time. Rather the vario check valve routes all water pressure either up or down.
The arms turn because the wash motor turns the pump (impeller) which drives the water to/through the wash arms. If the wash motor was faulty, you almost always get an error code. So the problem is probably caused by a blockage of the "plumbing" in the sump area beneath the lower wash arms. But first check all three wash arms to confirm that the holes are not blocked. (How cool is it that the light inside this model helps you do that?)
Next use a screw driver to remove the filter assembly in the sump area. There are 10 screws to remove, but first you need to firmly lift the lower spray arm directly up and out.
Inspect the entire sump area for debris. Watch out for broken glass! Look closely at the white area near the back for blockages at the check valve.
Please report back what you find and we will take the next step. OK?
May 18, 2009 | LG LDF8812 Stainless Steel Built-in...
Not enough water pressure to move upper arms or clean dishes
Recommend you pull the bottom spray arm straight up, then out of the DW.
Remove 9 phillips screws that hold the filter shroud down. Remove the filter and clean/rinse it out.
While the filter it out, grab a flashlight and inspect all over the sump area. Especilly in the area the has the check valve that rotates (Vario motor-driven) to feed the water pressure either to the lower and then the upper arms. Watch out for broken glass! Also, inspect the impeller to see if it is undamaged and spins easily.
Reassemble, then test out.
If problems remain, the the wash pump motor is probably the culprit. Do you get any error messages on the time display?
Good Luck!
Apr 05, 2009 | LG LDF6810ST Stainless Steel Built-in...
Viking dishwasher not cleaning bottom rack of dishes
Yes there is the Water Div valve, it diverts the water between the wash arms.
Mar 07, 2009 | Viking 24 in. Professional Series VUD141...
Upper spray arms not spraying water
It sounds like you have a model that has a pot washer cycle that blocks water flow to those arms. What cycles are on your keypad? Sounds like you have it set or single rack wash
Dec 08, 2008 | GE Profile PDW8400J Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
353 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
