Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Can you jump a battery without a charged battery? both of mine are dead.
  • pdvellucci Jul 15, 2009
    Thanks for the response. Not to happy with Makita though. The drill is great but I know several other people with battery issues too, and shortly after the one year mark. Two dead in a year and a half? If I buy a new kit it won't be from them. Thanks for your time though.
  • David Ford
    David Ford May 11, 2010
    I am not exactly sure what you are asking but I would contact Makita and see what they do. They havae a good warranty and you might be able to get 2 new ones
  • 9 Answers
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, the fusible link will blow (kind of like a fuse)
To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again.
If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering.
Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it!
Hope that helps.
Matt Binns
GiantGlobes.com
If your battery reads well below 10-12volts….
Try charging the battery with a car charger set on low (2 amps max) or a wall transformer from a phone or some such with a 12vdc output (make sure it is 12vdc not 12vac) You will need to know which of the charger wires is pos and neg, be careful not to short the battery as this will blow the fusible link. Connect + to + using jumper clips or stiff wire jammed into the battery contacts.
Once you get the battery over 10-12 volts the charger will normally accept the battery.
You can jump one good battery to the bad to do this, but in all cases watch out that the wires do not get hot, as this is a BAD sign, often a minute or two will be enough.
Of course you may have a dodgy charger, they are not robust at all.
The fans also ****, noisy and sometimes they quit, causing the charger to quit too.
Warning, these batteries pack a punch...be very careful and watch out for shorts, hot wires and exploding cells!
Matt Binns
GiantGlobes.com
Posted on Aug 18, 2009
  • 32 Answers
Makita carries a one year warranty free replacement and an extended two year if you purchased it when you bought the tool. No, you cannot jump it as you will kill it for sure. Make sure you charger is working properly, Green light flashing means improper power from your outlet or the charger has alot of dust in it and is running to hot, especially if the fan is not running the red light will flash. Blow it out with a moisture-free dust remover and try again. Plug the charger in first before putting the battery on. If the red and green light flash at the same time than the battery is bad. Solid red light means it is charging, solid green light means it is charged. If they are dead it is not cost affective to buy two new ones, as for a little more you can get a new kit and extra tool out of the deal w/ a new charger. Good Luck
Posted on Jul 14, 2009
Jump start
I would say you never checked to see if the battery is any good
I most likely is dead or below 12.6 volts & you never jump a dead
battery,you try charging it
Jumping is not charging a battery,you need to own a battery charger
If the battery keeps draining or won't hold a charge you need
a new one,then if the problem exists you have someone do a
Parasitic Current Test to find out which circuit is staying on
Aug 27, 2013 | Infiniti Q45 Cars & Trucks
Reversed polarity on jump start. now wont go into gear or hold charge
OLder cars YEs you can jump it without a battery. But in newer cars that use computers and advanced Eltronic ignition/timing/ful injection you have to have power to the cars computer. without a good battery the car will not run.---------------------------------------------------------------------------------
Renault CAN Clip
Feb 01, 2013 | 2001 Kia Rio
After jumping a dead battery the car will lose power and die while driving. It will however sit and idle without a problem. I did try testing the alternator by removing the positive lead from the battery...
You never jump a dead battery
That is an unsafe act and could
result in an explosion
You must charge any battery fully,
to start any diagnostic proceedure
You never remove either battery cables,
while a vehicle is running,another practice
that will bite you sooner than later
It sounds as though the battery is not
capable of taking a charge and offers
too much resistance to run the car hooked up
Mar 22, 2011 | 1989 Dodge Colt Vista
Batt dead jump start does not seem to charge
Sounds like a dead or shorted cell battery. Charging system is probably working but is showing overcharge since it is trying to charge a brick. Replace the battery and all should be well.
Jun 02, 2010 | Toro Lawn Mower With Toro Power Tools
Just bought a new battery.Whenever i turn anything on a/c,radio,headlights,the red charge lite comes on.Wont start without a jump.When it was running i took the terminals off the battery & nothing...
Never take the cable off when running. Its so hard on the voltage reg. And the alternator. Take the alternator and get it tested free at auto-zone or O rilleys. they test mine free all the time. Hope this is helpfull .. Sawdust46
Aug 18, 2009 | 1987 Chrysler Fifth Avenue
Batter won't stay up after jumping it off
Take the battery to an auto parts store and have them test it, most do this for free. If you can, take the alternator with you. If your able to keep the car running after the jump, try to drive it to the auotparts store for the testing.
Aug 07, 2009 | 1998 Volvo V70
Battery charged but will not start without jump
Have your alternator checked at one of the parts store around your area. They will check it for free. The next thing would be to have your battery checked. If you need a jump after the battery has been charged, you may have a dead cell. The alternator charging the battery....will not charge the battery for the next start.
Mar 29, 2009 | 1994 Cadillac Eldorado
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
323 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
