Pictures but no sound out of model ht302sd-do(diag lead ok)
  • ke004i8112 Jun 28, 2009
    hi, the speakers are ok, checked all the speaker outputs on there own no sound. looking at the circuit board inside one of the capacitors has a bulge on its top in the sound side of the board
  • 822 Answers
First check the speakers, and amplifier sections.
Posted on Jun 28, 2009
LG HT302SD Home Theater System i have problem in speaker in any option to work my all speaker now only 2 speaker work and other 2 not work pls help me
HI,
press the sound button on the players remote to select different sound field. select one which suits to you.
ok
Mar 08, 2011 | LG HT302SD Theater System
How do i play my ipod through my lg ht302sd
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Jan 29, 2011 | LG HT302SD Theater System
I have an LG dvd home theater system model no: HT302, plays everything bt no sound. So i've been tring to get to solve the problem bt still nothing comes right, so now i'm looking for pc board for these...
common the capacitors in the switch mode, use quality 105Degree smps caps.
the faulty caps are usually swollen, replace all while you have it open.
Jul 30, 2010 | LG HT302SD Theater System
Mainboard
I have same problem and hv
ave to replace board... can anyone help?
May 19, 2010 | LG HT302SD Theater System
Sound but no picture
ok make sure all the cables are plugged in properly and into the correct slot, Check all the channels and make sure that it is not on AV If this doesn't work try new cables or scart leads, if you use a scart lead plug it into a differnt location E.G Some T.V's Have more than one scart lead socket
Feb 06, 2010 | Televison & Video
No sounds when dvd is playing
If you can see the picture ok make sure the scart lead is fully in on both dvd and tv,if ok the try a new lead.
Aug 14, 2009 | Philips Televison & Video
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
Air flow seems low
ok dose this model furnace have a circuit board? if so there should be markings on the board where the blower leads are attached. such as cool heat park/or un used motor leads. and to speed up your blower it is going to be either the red wire or black wire they some times alternate you will have to see how the blower sounds or feels.. but you are going to replace the wire going to the heat terminal with a red or black wire and see how that works for ya. just makesure the power is off before sticking your fingers in there... also it may seem too obvious but ill say it anyway check ait filter and make sure all your dampers are open properly on the supply duct work
Jan 14, 2009 | Goodman GDS80904BNA Open Flame Heater
DVD playback no playback
Sounds like the scart lead is not in straight. Scart connectors have the audio pins at one end, and the video pins at the other. If the lead isn't in straight then you often get sound and no picture and vice versa.
Check the connection by pushing the scart lead in securely. (Both DVD and TV end of the lead)
Failing that could be a dodgy lead.
Mar 17, 2008 | Philips DVDR3380/05 DVD Recorder
329 people viewed this question
 Grubhead
Grubhead
