Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Our fan used to blow air excellently but now it bows air but it seems the air is from the sides of the
  • 822 Answers
Maybe the fan reverse connection.
Posted on Jun 28, 2009
Fix fan
A Cooling pad will do very little if your fan is already clogged up, Try blowing compressed air into the exhaust port of the laptop to free it up, Do not blow compressed air into the fan blades causing it to spin fast, this will cause damage to the cooling fan, short bursts of air into the heat-sink fins should be enough to dislodge most of the dust. if you find you're using it on a bed or on your lap where you're blocking the bottom of the machine, consider getting a cooling pad.
Cans of compressed air can be purchased at computer stores and other specialty shops, it shouldn't be too hard to find, and is not expensive.
Oct 20, 2012 | Compaq Presario CQ56-115DX Laptop
The ac is not blowing air
there is a resister for the blower motor near the motor under the dash behind the glove box the connectors over heat then they loose electrical contacts look at the connector for melting
Jul 12, 2012 | 2004 Cadillac CTS
Check charge and it shows proper pressures and still blowing hot air
ARE WE LOOKIG AT A CAR OR HOME UNIT
HOME UNIT AC COMPASADOR KILL POWER TO AC MOUNTED ON SIDE OF INSIDE UNIT SMALL CAN WITH 4 WIRES TOP OF CAN WILL SHOW SIGHNS OF BOWING OUT,THEY WILL BE # LIKE
5 - 30 MAKE SHURE YOU MATCH # UP WEA RUBBER GLOVES
EVEN POWER IS OF THE WILL BE ENOUGH POWER TO GIVE YOU A GREAT JOLT KEEP AN EYE WHAT WIRES GOES WHEAR COMPRESSOR FAN WILL START AGAIN THE UNIT HAS 2 FANS ONE TO KEEP CONDINSOR COOL AND OTHER TO KEEP COMPRESSOR RUNING GOOD LUCK PART $90
Jul 07, 2012 | Heating & Cooling
I have a Eureka The Boss Power sweeper but can't find my Owners Manual. It seems to have lost some vacuum power. It doesn't pick up cleanly, leaves a streek of residue behind and seems to be blowing air...
Blowing air out of the right side? As in blowing air out of the right side of the hood? If its a light stream of warm coming out of the vent in the hood that's normal, its exhaust air from the motor. Now, clogs can occur at the outlet from the fan chamber. Remove the bag from the base of the machine via two screws. See if that area is clear and the tube going up into the bag unit is clear as well. Now, if the fan chamber is clear, inspect the fan for breaks or missing blades.
Dec 12, 2017 | Eureka 1934 Bagged Upright Vacuum
Fan does not blow in the front for air conditioner
most common problem on this vehicle is the blower motor resistor
less than $40 and only two screws to remove
May 08, 2010 | 2002 Chrysler Town & Country
A/C blowing hot air on driver's side
You have a faulty switch. Go to the salvage yard and buy a used one, pull off the trim panel and replace it. I just did one of these last week with the same symptoms.
Oct 15, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
My dell inspiron notebook 6400 shuts down and starts up automatically...what is going on...I don't use a battery so its not that...just use the ac
By your description it sounds like your laptop is overheating. Many a laptop faces this issues because the Air Intake Duct is dirty, and the internal hardware.
When a processor in a computer becomes too hot, it shuts off. (More specifically BIOS turns it off) NO processor running, NO computer.
Since the opening for the Air Intake Duct, (Left front side), is on the side close to the bottom, it makes an excellent(?) location to 'inhale' foreign debris. Dust/Dirt/Hair/Food Crumbs/Lint, you name it.
When this foreign debris goes inside the Air Intake Duct it clogs it up, dramatically reducing the cooling efficiency of the cooling system.
The Air Intake Duct is connected directly to the System Fan, and this fan blows air through the Cooling Tube for the processor, and graphics.
The Cooling Tubes, One for the Processor, One for the Graphics), is about the width, and height of your little finger!
Solution?
Use a can of compressed air for computers, and blow out the Air Intake Duct. (AC adapter removed,{Charger}, and battery removed)
Do NOT blow out the Exhaust Duct!
Use Short Bursts of air, not Long bursts.
You will be blowing air directly on the System Fan. This fan is only designed to spin so fast. Spinning it faster than it was designed for, can lead to premature failure of the fan's bearings.
Take a look at this,
http://support.dell.com/support/edocs/systems/ins6400/en/sm/compnts.htm#wp999507
See Number 12? That is the Processor Thermal Cooling Assembly. The copper colored S-shaped piece is the Cooling Tube.
Number 14 is the System Fan.
This is the Service Manual main page,
http://support.dell.com/support/edocs/systems/ins6400/en/sm/index.htm
Would appreciate it if you would rate my answer.
Jul 19, 2009 | Dell Inspiron 6400 Notebook
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
225 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
