Question about Jandy Aqualink Rs4 One Touch Control System Control System
Solar disappeared from display
We had a power outage and the solar panels disappeared from the display. I can get the valve to open properly when I press "Solar" on the main panel, but on the Aqualink it doesn't even show up.
I assume one of the labels (most like the "Extra Aux") has just reset and no longer says solar, but when I try any of these it doesn't switch the solar valve -- although the valve itself opens when the pump comes on.
Diagnostics says the solar sensor is opened -- so I assume it has failed (I've replaced sensors on both the air and pool many times in the past. Sigh). But that doesn't explain to me why I can't get the valve to open (or even show up) on the Aqualink. Or does it?
So... I guess what I'm asking is, will replacing the sensor in the solar panel resolve all of this? (The solar sensor is one I really can't replace myself, since it's on the roof and I'm an old man).
    Champion:
  • 246 Answers
Well the old man said it replace the solar sensor but not need to be on the roof just make sure it get sun rays sh is a secret.
Posted on Dec 08, 2009
Why is my GL235 solar heater control panel not heating the pool. The heating light is on and the power light is on. What should we do.
If water is flowing thru the panels/collectors, (look to see if the valves are opened to allow water to the collectors) if the water is flowing and it is flowing through the collectors/panels, then the water is being heated!
If you are saying the controller is set for solar operation and the sun is shining, and there is a "Demand" for heat or a "Call" for heat, and the Valve is NOT turning to allow the water to the panels, then you have a problem with either the Hayward/Goldline Controller or the Valve Actuator.
Good Luck
Nov 15, 2014 | Goldline Solar Pool Control Package Gl-235...
Solar has disappeared from my Jandy Aqualink RS control
go into system setup assign the solar to a aux it should work
Apr 10, 2014 | Jandy Aqualink Rs4 One Touch Control...
Using solar panel to power small appliance
If you guys want a free way to get your electric and natural gas supply for free in PA,NJ,CT,NH,ME,RI,NY,MD,OH,ILGA.,Texas .Get you Energy company to pay you every month too. Call me : leave a message I will get back to you ASAP .i will be happy to help .People helping people .Scott at 267-549-3746.
Mar 31, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
Are solar chargers heavier than regular chargers?
Naturally due to the size of solar chargers they are going to be a little heavier than a regular charger, but keep in mind that solar chargers are able to charge you device so long as the sun is up.
Oct 14, 2013 | Electronics - Others
How many major companies have solar panels?
click in this link
http://en.wikipedia.org/wiki/List_of_photovoltaics_companies
scroll down on page to see manufacturers.
Hope this helps.
Dec 03, 2012 | Computers & Internet
I have a solar pump kit using an OASE Aquaflow 1500 submerged unit .The pump will spin when connected to a car battery but when attached to my solar panel which is producing 21 v on open circuit it will...
Hello Phil, what is the size of your solar panel? This pump draws 17 watts so, your panel must be 17 watts or greater. Remember a solar panel only puts out full power when in direct sunlight and facing the sun directly. You can read 21 volts but your amperage may not be full and this is why your pump is not running, not enough amps. I would recommend a minimum of a 20 watt panel.
Feb 14, 2011 | Plumbing
How to setup a diverter valve for above ground
If you want all your water going thru the solar heater before re-entering the pool, you'll need to plumb the end of your filter to the solar heater, then the water exiting from the solar heater would go where the filter hose did go back into the pool. Hope this helps.
May 25, 2010 | Fafco Deluxe Solar Panel Heating System 1...
I have a trace inverter DR 1512, I am having a problem with my system, which includes a 5000 watt gen, and solar power. When I am dry docked and have solar, system functions fine, when I lose solar and go...
the solar panel is just to charge your inverter,if it is charging and the inverter is on it will drain the current the solar panel is supplying to the batteries,this makes it look like it is not charging ,so i advice you to switch off you inverter when charging it,get another set of batteries connected to your solar panel then charge both, let them be separated so that the new one is not in use so that when solar is out you can switch to the other set of batteries
Nov 25, 2009 | Xantrex Technology Trace Series Inverter /...
Freeze Protection for Sola Panels
Running water through them all night would prevent them from freezing, but it wouldnt help the cause, as it would be cooling the water and using electricity. When I installed solar panels I used isolation valves, and simple drains that were to be opened to allow the water to drain out. Glycol does not enhance the heat transfer, as plain water is best - it is only for antifreeze. And you dont want anitfreeze in your pool.....
Mar 20, 2009 | Fafco Deluxe Solar Panel Heating System 1...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
332 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
