Question about RCA Analog (RCA) to Digital (USB) Converter for PC w/ Audio (003-VID-AD02A)
RCA DTV converter box no signal channel 2 & channel 7
Before hooking up DTV box last sunday able to receive all channels with rabbit ear antenna. According to info on net the channels should still come thru with a DTV converter box hooked up. Re-scanned 4 times and still no signal for ch. 2 & 7. Also tried to move antenna around to pick up signal and still nothing. Talked with RCA customer svc. last week & they said problem was with ch. 7 but other people I know have both channels with their DTV boxes one of which is a magnavox. Problem according to RCA cust. svc. was supposed to be fixed as of friday 6/26/09-still no signal. Should I exchange box for a different brand or?
  • 21 Answers
SOURCE: I have purchased the converter
THE CONVERTER BOX HAS R.F. OUTPUT. JUST HOOK IT UP AND PUT THE T.V. ON CHANNEL 3.(OR WHAT EVER THE INSTRUCTIONS THAT CAM WITH THE BOX) YOU WILL NEED TO CHANGE THE CHANNELS WITH THE REMOTE THAT CAME WITH THE BOX. YOU MIGHT NEED TO SET UP THE BOX (SCAN FOR CHANNELS) THAT IS ALL IN THE INSTRUCTIONS THAT CAME WITH THE BOX.
DON.
Posted on Jun 15, 2008
h_leslie
  • 27 Answers
SOURCE: how can this be happening if she is not hooked up to the cable
if you see the logo she has directv. tune her t.v. to channel 03 or 04 and she should have a picture,if she lives in a apt. her feed may be coming from her provider or her t.v. is hooked up to another t.v. that does have a directv receiver. if this doesn't solve your riddle get back with me as i work for direcv in the tech dept. hope this helps you...
Posted on Dec 17, 2008
  • 12 Answers
SOURCE: I have an RCA converter box hooked up to an RCA tv
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Posted on Feb 27, 2009
DickCanFixIt
  • 948 Answers
SOURCE: NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Posted on Apr 08, 2009
  • 864 Answers
SOURCE: No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
Posted on May 30, 2009
I am in Los Angeles,Ca. Converter box signal problem
Just go to walmart and buy a good digital antena.Should work great.Just rescan all ur channels again.
Mar 11, 2010 | Digi Sansonic FT-300A tal To Analog TV...
I havce installed the digital converter box and everything seems to be okey. I get the menu page, and do a channel scan, which brings up no channels. With the converter turned off, I get a cable signal...
1. If you are using the composite video output, double check that your antenna is connected to the converter's antenna input and not the output.
2. If you are in a remote area that gets signals through translators, there might not be any digital signals to receive.
Is the antenna connected to the input of the converter box? There should be a screw on connector on the back, the antenna connects there.
If you have the antenna connected properly, have set the conveter to scan for channels, and you were able to watch TV with the rabbit ears before you got the box, the box may be defective....!!
Thank you!!!
PLease post back for further assistance..
Regards!!...
Jul 31, 2008 | RCA Televison & Video
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was...
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Unable to get consistent reception on ABC (channel 7 NY)
The antenna may be the problem in your case but I was getting New York 7 digital with a strong signal before the transition on June 12th and now I do not get any signal. I use a rather large VHF /UHF roof antenna mounted in my attic. The compass heading for NBC NY 4.1 is 169 deg and 18 mile from my location according to antennaweb.org. I get this channel with a strong signal. Comparably ABC NY 7.1 is 170 deg and 18.7 miles from my location and I do not get a signal. Perhaps ABC NY is having some problem with the transition. It does not make sense assuming the information of antennaweb.org is correct. BTW if and outdoor or attic mounted antenna is not an option I would recommend the following antenna. I used this for my friends? setup when she was having problems with rabbit ears. It also got some pretty high user reviews and is not expensive. It is for both indoor and outdoor applications. Good Luck! http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10901&cs_id=1090102&p_id=4730&seq=1&format=2
Apr 10, 2009 | RCA 20F514TD 20" TV
2- Converter box
3- Television
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
No channels downloaded
The antenna must be hooked up to the converter box. The better the antenna, the better your reception will be.
Not everyone in the country will be in range of digital signals. Digital signals have a shorter range than analog signals do right now. It is possible (but unlikely) that you are not currently in range of any digital signals.
So make sure you are set up like this - Antenna--converter box--Television. Then scan for channels. You should still pick up any analog signals while the box is hooked up, you will just view them the same way you do now, by changing the TV station rather than the converter box station.
Dec 06, 2008 | Insignia Digital-to-Analog Converter for...
Magnavox TB 100 MW9 STB Converter Boxes I'm trying to solve the antenna/rabbit ear connection from this converter box to the t.v. I only get a pic when the rabbit ears are connected to the back of the...
Analog signals have nothing to do with your problem. Make sure that the TV is set channel is set to 3 or 4 (cf read of Converter box for channel switch). The TV received signal from Converter box on Channel 3 (or AV Cables if you have them)
Jun 11, 2008 | Televison & Video
RCA Analog (RCA) to Digital (USB) Converter for PC w/ Audio (003-VID-AD02A) Logo
516 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
