Televison & Video Logo
Posted on Jun 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
L channels deleted fro memory how can i add all the channels back
When I hit menu on my tv it says scan memory channels add or delete. Mine all are deleted so I can nt see any . what do i do. what buttons should I push
jesse michael turner
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 26, 2013
Contributor
Level 1:
Answers
Questions
0
Helped
368
Points
0
Hey i have a sanyo DP-42841 flatscreen tv,how come when i hit a channel number it shows not avalible?theres at least up to 5 digits my tv channel will display,how do i fix this to where the higher up channel numbers will be avalible just thru my tv?
Anonymous
Level 3:
  • Master 1,056 Answers
  • Posted on Jun 28, 2009
Anonymous
Master
Level 3:
Answers
1056
Questions
Helped
363372
Points
3277
Press auto program. make sure you have an antenna, and that you have a converter box for the digital system.
Anonymous
Level 3:
  • Master 508 Answers
Anonymous
Master
Level 3:
Answers
508
Questions
Helped
202787
Points
1515
Push channel button then add!!!!
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
How do I delete channels not wanted and get channels I have lost the past couple of days?
just press the menu either in the remote controller or in the tv panel. and then go to channel set up this time you can delete channel and can add channel you want and then save in the memory.
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
Tv is hooked up to dish. channel 73 for dish programing. channel 73 was inadvertly deleted using remote, how do i get it back? thanks, dab
In the menu on the TV there will be a section for channels. There you can add or delete existing channels. Or you can just push the 7 and 3 button ion the remote then hit enter and it should go right to the Channel.
13helpful
Dont know how to do a channel scan on my samsung 2333hd t.v
Using the Color buttons on the Remote with the Channel List.
• Red (Antenna): Switches to Air or Cable.
• Green (Zoom): Enlarges or shrinks a channel number.
• Yellow (Select): Selects multiple channel lists.
• TOOLS (Option): Displays the Add(or Delete), Add to Favorite(or Delete from Favorite),
Timer Viewing, Channel Name Edit, and Auto Program menus..
Auto Program
The TV automatically cycles through all of the available channels and stores them in memory.
In rare cases, "Auto program" may miss a few channels due to weak signals and the channels may
not be added to the channel memory.
Air
Cable
Auto
MENU → arrow up, arrow down→enter → arrow up, arrow down→enter →arrow up, arrow down →enter →arrow up, arrow down, arrow left , arrow right →enter → MENU,EXIT.
Hope this helps. I have the owners manual on file.
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
I cannot find the code for my (ilo) brand TV from Wal-Mart and after the scan the scanner does not pick up on a channel I know is there. My friend has the working channel on his digital TV, but it...
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
1helpful
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
2answers
Durabrand 13 inch tv
the remote need to clean pcb board ..... the chroma section pcb need to resolder loose parts such as resistor, capacitor or transistor that you may see on it.....
1helpful
Channel
Press menu key
highlight channel scan memory
press vol+ to highlight number entry area
enter channel you want to enter eg. C16
or if above 100 press and hold the 1 key until C1--pops up
change deleted to added by pressing vol+
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
