Question about Whirlpool Refrigerators
I can herar water runnging inside the regierator.
I have top freezer whirlpool the is less than a year old and i hear water running sometimes? we have an icemaker in it but not hooked up, we keep the bar up at all times.
Alos noticed a thin layer of ice onthe back of the feezer wall, are these two probelms related? Am I suppose to hear running water inside the refrigeratr? It's not leaking?? please help
  • 82 Answers
You are probably hearing water running out of the unit during a defrost cycle. It runs inside a tube to the underneath of the refrigerator where it is collected in a pan and evaporated into the room by heat from the compressor fan.
Posted on Jun 29, 2009
Whirlpool Gold side by side frigerator freezer ice and water not working, inside frigerator various places freeze, on certain shelves units only 5 years old
As far as the icing up sounds like your cross over have ice. Unplug and defrost even on frost free. Should solve both problems
mike
Dec 19, 2017 | Whirlpool Refrigerators
Why is water leaking into the refrigerator from the freezer?
The defrost drain in the freezer is clogged. The defrost water then overflows and runs down the vent where the cool air enters the fresh food section and makes a puddle on the top shelf. You may defrost the unit over nite or have a tech come check it. If you just defrost it and there is some type of debris in the drain line that will not melt then you will still need a service man. Or if you feel brave, and can be totally careful so you will not get cut remove the back wall of the refrigerator after you unplug it and get some towels and boil some water. Gentle pour the hot water into the area below the evaporator, ( the thingy with all the aluminum fins), You will eventually hear the water emptying into the pan beneath the refrigerator. Once you hear that you can reassembly and resume operations.
Dec 31, 2017 | Whirlpool Refrigerators
Model #GX5SHDXVB03 freezer floor filling with ice (water run down back then freezes)
So I figured out what the real problem is with this model of freezer. There is an updated drain that needs to be installed. The old version gets plugged from dust and no amount of thawing will fix it. if your appliance is less than 2 years old the manufacturer will pay to have your appliance updated with the new part. If your appliance is over two years old they will send you the new part for free.
http://www.amazon.com/gp/product/B0156NFUV4?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Feb 28, 2012 | Whirlpool Refrigerators
There is water that is freezing inside the bottom of the freezer. I turned everything off and cleaned out everything including vacuuming the back. The unit is less then 4 years old
In the bottom of the freezer there is normally a plate you can remove and expose the drain. It is probably clogged, just use a wet dry vacuum to clear. Also debris is sometimes to blame.
Apr 27, 2011 | LG LRTBC1825T Top Freezer Refrigerator
Freezer is not defrosting
Sounds as if the drain line in back is stopped up in the freezer section. Sometimes the insulation which is foam the excess settles in the drain area must be cleaned out. You will have to remove the inside of the freezer section to get to it. It;s best to take outside and use a water hose to flush it out. A messy job but it works. BB
Dec 15, 2009 | GE Profile PTS22LHSBB 33" 21.7 Cu. Ft....
I have water pooling on my fridge trays and than turning into ice . The water seems to be coming from the vents. How do i get rid of that.
The freezer compartment has a drain hole behind the back wall inside the freezer compartment. The drain hole has probably rusted and has gotten larger. Carefully remove the icemaker and the screws from the back wall inside the freezer compartment. Lift the bottom of the back wall and look to see if the drain hole has gotten larger. You can make a small funnel from an aluminum can to fit over this area directing the water into the drain tube. It worked for me. good luck. Dave.
May 10, 2009 | Whirlpool ET9FHTXM Top Freezer...
DEFROSTING/ WATER RUNNING ONTO FLOOR & INSIDE FRIDGE
Check to see if the run-off tube at the back is plugged.
I dont know how old the fridge is - but if it a couple years old check at the back or the fridge - there should be a tube running down the back of the fridge down into the bottom tray. This tube funnels water from the freezer (condensation, or water from the defrost) down onto the tray holding the compressor where it evaporates with help from the heat off the compressor. Sometimes this tube can get plugged up with some scum or mineral deposits, causing the built up water to drain from inside the fridge.
The tube shouldn't be too hard to remove and clean out with some hot water and pipe cleaners. Had the same issue on on a GE fridge last year.
Hope this helps!
Dec 30, 2008 | Whirlpool ET0WSRXML Top Freezer...
Problem with a Whirlpool Upright Freezer
One way would be to unplug the freezer and allow all the ice to melt.It will open the path for draining.Then plug it back in making sure that there is know gaps on your door gasket that would allow warm air in which would make the same problem.
May 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Top Freezer Whirlpool
THERE IS A PROBLEM WITH THE DRAINAGE. iTS BLOCKED. YOU NEED TO DEFROST THE FRIDGE PROPERLY FOR A DAY TO REMOVE THE ICE THEN APPLY PRESSURE (BLOW) IN THE PIPE SITUATED ON TOP OF THE COMPRESSOR.THIS WILL CLEAR THE BLOCKAGE. RESTART YOUR FRIDGE.
Aug 14, 2007 | Whirlpool ET8WTMXK Top Freezer...
Refrigerators Logo
48 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
