Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Sears Kemmore Mode; Refrigerator side by side model 106.9557621 How do remove door handle
  • 999 Answers
The upper and lower trims have to come off for access to the handle screws. Some just slide up or down and some have screws on the top and bottom of the door. Carefully pry them off.
Eric
Posted on Jun 29, 2009
Where can I get new door handles and new vegatable bins?
Try sears parts direct. You need a model number, b/m number. This number starts with p.Like p3456678. Ok this p number is very important. It tells all small details. Ihope this helps.
Aug 26, 2011 | Amana ARS2464B Side by Side Refrigerator
Our Kenmore Side by Side refrigerator ice maker is not working- I'm not sure I found the correct tag inside the refrigerator side of my side by side that said: model #596-526-79202 ... Serial#...
Well that is better model numbers than most people give! The first three numbers say the refrigerator is an Amana. Sometimes the Kenmore and the OEM number gets lost in the translation and it makes it a little more difficult to pick the exact model number by Amana. Sears Parts Direct you will need to put the numbers together like this=> 596.52679202 Repair Clinic can also convert model number to parts here=> 596.52679202 You can also go to Amana and begin your search by features=> sea_breeze_118.jpg Click Logo This is where Sears drops the ball and you will need to compare => side by side's French Door and then=> Literature again until you see your model number
Then=> Once you see your model click=> Literature
That breaks your model number into Use and Care (1616.87 KB), Warranty (126.21 KB), Dimension Guide (78.58 KB), Energy Guide (97.01 KB), Specifications Sheet (434.26 KB) Once you find the exact Amana Model Number I will pull the Service Manual up and need to contact you a different way because they will not let me post their Service Manuals here. Sea Breeze
I hope I have not confused you but that is the way you will need to get the answers once Sears changes the model number. Your model uses a=> 67003153 Ice Maker Assembly That ice maker is made up of components that sometimes fail. Here I leave you with a short tutorial. If you have further questions please contact me here or Fixya, Thanks, Sea Breeze
Mar 18, 2011 | Refrigerators
I have a side by side samsung fridge freezer and it wont fit through my front door can you remove the door handles?
See if the end caps will pry off of the handles and see if there is a screw holding it on. You need to post your model number for more specific info.
Feb 14, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
How to move refrigerator handle to opposite side
In some cases they are designed in such a way where all you have to do is to remove the door and re-install it upside down to locate handle to the other side. Check to see if that's the case with yours!
Nov 04, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE French Door handle loose
To tighten the screw the first step is to remove the handle. With this model just pull straight up on the handle. It can take a little force but after it finally unclips it moves up an inch or two then pulls straight out. Good luck!
Nov 07, 2008 | GE Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
398 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
