Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
Throttle cable on Ryobi cs30
I was taking the housing off to get to the pull string area to troubleshoot it when the throttle cable disconnected from the carb area. I can't seem to figure out where to reconnect it and there is no diagram in the manual. Does anybody have a diagram or picture to help me out please?
  • mcbsprez Jun 28, 2009
    Thanks for the quick response.I will have to say that I am frustrated with Ryobi equipment. I followed you instructions and entered the info and it said it does not exist. I know I entered it correctly. I am going to call them tomorrow. I have had this one for 1 year and two weeks. They ended up switching it out for one I owned for 2 weeks that would not run for more than 10 minutes without conking out. They admitted a problem with conking out and I see a lot of posts by people with similar problems. Again thanks for your help. I will see if they keep my future business when I call them tomorrow.
#1 Taper
  • 1041 Answers
SOURCE: Ryobi CS30 will start but when I pull on the
Check the fuel lines first for cracks. If they are cracked or brittle, replace them. Also, your carburetor may need cleaned. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals. Make sure the small screen in carb. is free of debris. The smallest of particles can cause your problem. Reassemble and try starting. If it still acts up after all this then you will have to purchase a carb. kit and replace all appropriate parts. If you need tips on these remedies, feel free to ask.
Jim
Posted on May 30, 2009
connertamago
  • 37 Answers
i know what u guys got going here. you proably left it i the garage over winter with gas in it. maybe not. anywho, there is a diaphgram in the carb that pumps the fuel in via vibartions of the motor. poor design alont ith fuel filterINSIDE AND AT ONE END of the gas tank. anywho, this diaphgram is ruptured, and i bet there's also gas coming out os the carb and dripping off the choke selector?
this is a job for a small engine mechanic
Posted on May 31, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi CS30 straight shaft. I can not get the
There should be a half sphere shaped object over the spool of string. Twist off in a counter clockwise motion and the spool will come off so that you can replace the line.
Jim
Posted on Jun 19, 2009
panilling9
  • 284 Answers
SOURCE: ryobi cs30 starts fine, but idles way too fast
you need to take your air filter off and look into the throat of the carbruetor to see if the ""Butterfly""
is still intact and working not the choke butterfly its the one closest to the engine that moves with the throttle and be sure it is still there and moves as you move the throttle.... open is horizontal and closed is not quite 90 Degrees. check to see it is tight and in the center if the throat when closed.
you may have to remove the carb. to see it function more clearly
make sure the throttle cable is free and not binding any where and to be sure of its adjustment to allow the throttle to return to the idle position.
lubricate the cable from the trigger to carb. wd 40 is ok.
if all above is ok then find the L on the carb. and ccw it 1/8 turn to ritchen it alittle to help slow the idle down some to a respectable level
Posted on Jul 04, 2009
  • 15 Answers
SOURCE: Ryobi CS30 - Stalls out?
Dirt or varnish in fuel filter or carburator. Change filter if there is one.
Flush out the carb with a varnish remover.
Open high speed needle valve 1/8 turn farther, then turn in while running until it just smooths out.
Posted on Jun 07, 2010
How to replace the fuel tank
308181004 Homelite Ryobi String Trimmer Fuel Tank ...
www.amazon.com > ... > Replacement Parts
Amazon.com, Inc.Amazon.com: 308181004 Homelite Ryobi String Trimmer Fuel Tank replaces ... Ryobi CS30 & Homelite C300 Trimmer Replacement (2 Pack) Air Filter # 98760-.
Oct 07, 2015 | Garden
My Ryobi cs30 weed eater tends to shut off after I release the throttle.
Find the idle speed screw (not the jet screw) and turn it CW until the engine idles without dying. If too high, the string head will turn all the time. Hope this helps
Sep 06, 2010 | Ryobi Garden
Ryobi string trimmer RY34420 has a non retracting pull cord. How do I fix it?
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Aug 31, 2010 | Ryobi Garden
How do i take a part ryobi cs30 trimmer to replace the pull cord?
Here's a link to step-by-step and a video for a Ryobi SS30 string trimmer. I do not believe there are many (if any) differences between those instructions and you trimmer.
Aug 18, 2010 | Ryobi Garden
How to replace throttle cable on 2006 harley roadking
remove 2 screws from right handle bar switch open it up and remove the cables from the throttle sleave. to remove from housing move in a circuler motion while pulling them from housing they will pull out as long as you pull them straight. then remove air cleaner cover and backing plate you will see where the cables hook to throttle bodies unhook cables and remove from holder noteing the one with the spring. tie a string to the end of the 2 cables anf pull them through the top, then tie the string on the new cables and pull them back through and re install everything and adjust the cables to 3/8 play in the throttle and done.
Aug 03, 2010 | 2008 Harley Davidson FLHR Road king
Trying to replace pull cord on ryobi cs30. How do
how do I repair/replace the pull cord on my Ryobi CS30?
May 22, 2010 | Ryobi Garden
Ryoby weedeater throttle housing. Replacing the throttle spring
From the limited information you have given I think your throttle wire is binding. It could just need lubricating or the throttle shaft or butterfly in the carburetor could be binding. Disconnect the throttle wire from the carburetor and see if the throttle wire is moving freely and check the throttle shaft in the carburetor to make sure it is moving freely. If both are free, then check to see if something is pinching or binding on the throttle cable.
Sep 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi cs30 starts fine, but idles way too fast after warm up. I mean screaming fast. Throttle return works fine and idle adjustment is set at it lowest.
Jul 04, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have a Ryobi Reel Easy bumb feed stringhead on my Cs30 Ryobi weed eater with an expand it curved attachment. Loading the replacement string is no problem, but getting it to come out is another problem. I...
what model is trimmer? cs30? if you found the line on it clockwise, that's your problem. on the cs30 it rotates counterclockwise if youre looking at the head while trimmer is upside down. the line has to be wound opposite direction or your going to have a MESS of string in the head.
May 13, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
1,102 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
