Goodman condenser model GSC130361DF. compressor
Goodman condenser model GSC130361DF(was installed 4-06/09). Compressor runs for about a 1/2 hr then shuts off, blower also shuts off at same time. Maintains inside air temp about five dgrees above thermostat setting. Any ideas?
  • 1,056 Answers
That is normal too me. Just set it lower for more comfort.
Posted on Jun 28, 2009
Why does the compressor on my goodman package unit turn on and off before completing a cycle while the condenser fan runs?
Two most common issues are a bad run capacitor or the compressor is over amping due to bad bearings.
Sep 02, 2014 | Goodman Heating & Cooling
Goodman condenser GSC130361DF BAD BALL BEARING SOUND.
The compressor has to be replaced if the bearings are bad in the compressor. Replace the condenser fan motor if the fan motor bearings are bad.
Aug 29, 2013 | Goodman CKL42AR42 Air Conditioner
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
Have a ckl24 condensor bad compressor. Can it be used with a 2 1/2 ton compressor
no you cannot put a 2 1/2 ton compressor into a 2 ton condensor. you could put a smaller compressor into a condenser and you will gain effeciency put loose capacity
Sep 07, 2012 | Goodman CKL24AR24 Air Conditioner
Goodman compressor not running after power outage
no reset replace capacitors. check terminals on compressor to see if a wire burned off
Jul 31, 2012 | Goodman Heating & Cooling
I have a ( Goodman CKL-49 1 ) fan was not running, I used a small wooden stick to get it to run. fan is now running but cold air is not being produced what can I do can you please help?!
The split run capacitor in the condensing unit is bad. It needs to be replaced. The reason the system is not cooling is because the compressor it not running. The capacitor is needed for the fan and the compressor to run properly. That is why you had to give the fan a kickstart with a stickstart.
Hope this helps.
Sep 08, 2011 | Goodman CKL49AR49 Air Conditioner
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
Goodman Evaporator fan runs continuosly
first disconnect the green stat wire wire could be bad if still runs change the board on the indoor unit pull board and take to goodman store with model number and serial number its under warrenty they will give new one hope this helps also look at dip switches and instructions to make sure ok
Jul 08, 2009 | Goodman Heating & Cooling
Goodman compressor cuts off when temp too high
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
967 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
