Question about Fellowes Office Equipment & Supplies
Shredder slow, loud, paper often stops
My Fellowes Shred300 works slowly, the paper moves, stops and moves, and its loud (perhaps gears). It only works w/one paper at a time. I lubricated the blades with a bit of light machine oil but the problems remain. A sign on it warns against opening so I have not checked for dust, etc. Advice? I can't find an online manual. It's probably an older model.
dlundmark
  • 797 Answers
SOURCE: Fellowes Shredder Parent Part # 38605
If this unit is worth it to you, you can build your own gear.
Here is a link to get plastic repair materials to make plastic parts. This site also will have materials for repairing plastics.
Another possibility is to search Ebay for a unit like yours which has other problems. Never can tell... it may be there.
Make sure you ask for the model of the unit in your search (on the NET as well. The serial in this case is not needed.
Posted on Jul 26, 2008
FixinFax
  • 3085 Answers
SOURCE: Staples(Fellowes?) micro cut shredder - blades not turning
Sometimes the main gear is attached to the motor with an ALLEN SET SCREW
Posted on Jul 05, 2009
  • 1126 Answers
SOURCE: need an online instruction book - for fellowes shredder 50CS -lin
http://www.fellowes.com/Fellowes/site/support/support_manualsdocumentation.aspx
Perhaps you can locate your model number here....hope this helps.
Posted on Sep 05, 2009
Testimonial: "Thank you very much for the instruction book for the shredder 50CS - it is brilliant, and we actually shredded the instruction manual by mistake !!"
SOURCE: od700c shredder: motor spinds, blades don't move
Inside the motor assembly there are a series of nylon cogs , a large one of which interacts with a metal one.  This is the most likely place you have one or two teeth missing from the large nylon cog that drives the shredder blades.
Posted on Oct 05, 2009
  • 610 Answers
SOURCE: Need replacement main gear for fellowes shredder
call fellows at 1-800-955-0959
Posted on Nov 18, 2009
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
Can you take apart a fellowes PS-12C
FELLOWES SHREDDER
May 23, 2014 | Fellowes Office Equipment & Supplies
Oil Used WD-40
A gear is probably stripped. Fellowes sells gears for some of their shredders, but gear replacement is a messy job! Oiling it will not usually fix the problem; you need to contact Fellowes directly.
Apr 16, 2014 | Fellowes DM12C Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 12, 2009 | Fellowes S701CM Shredder
Fellowes p45C
Please call us (Fellowes) at 1-800-945-4545 to check and see if this is a warranty issue or if we can troubleshoot the machine for you. It sounds like you may have a gear that went out
Mar 18, 2008 | Fellowes 3011001 Shredder
REALLY LOUD
your question should be able to be answered here 1-800-789-1331 I tried to find info on decibels but unlike FELLOWES they don't seem to provide that but try this number and they should be able to help you
Feb 26, 2008 | IdentityGuard Cross-Cut Shredder
79 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
