Question about Kenmore 44072 Front Load Washer
Front panel is frozen. Washer won't start or reset.
2 Suggested Answers
SOURCE:
blueextc3221
  • 15935 Answers
SOURCE: HE3T Control Panel seems frozen
Unplug for 40 minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Why won't my maytag neptune front loading washer will not start?
Check out the door switch to make sure that it closes when you latch the front door. If it does not close the machine will be inoperative - safety measure.
Sep 19, 2017 | Maytag Neptune MAH5500B Front Load Washer
The door lock won't open. I unplugged unit to reset, but still can't open door.
try finding the manual release..on my bosch nexxt 300 there is an access panel on front lower right of unit for the drain if i open it and reach up there is a cable to pull on to manually unluck the door...have wet vac ready as there might be water from a clogged drain causeing washer to keep door locked
Oct 10, 2011 | Frigidaire ATF6000ES Front Load Washer
The washer programme has frozen and stuck on a cycle. how do i reset programme?
try unplugging the machine for 10 minutes,plug it back in and see if it will reset,if not you could have a button stuck inor a bad touch panel,send the model number next time located around the door opening.
Nov 28, 2010 | Hotpoint Ultima WF860 Front Load Washer
Aug 10, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My duet washer is locked and will not reset
To open the door,remove the bottom panel. Teach up inside on the lock side and find the pull ring. Pull on the ring while putting pressure on the door. It will open. Have the door lock wax motor and mechanism replaced.
Jul 17, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer maytag stopped working during wash
the start button is part of the board their.if you hear frying noise their when pushing it there ,you may have a failling board.god bless your way.Tom
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer is on but won't return back to cycle - Frozen
Hmmm..just a simple option would be to make sure nothing is blocking the door from closing all the way...if that doesnt work Id try unplugging the machine and plugging it back in to reset the computer.
Dec 24, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 44072 Front Load Washer Logo
74 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
