Question about Microwave Ovens
This morning we boild over some water on to the range top and ever since no matter what I do the ignitors will not stop igniting even when the flames etc. and gas are doing fine. I have to unplug the cord from the range underneath the cabinet to get it to stop.
  • 583 Answers
few things that can cause this problem:
check for the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module ON .If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 28, 2009
Kitchenaid Superba range oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Apr 26, 2011 | KitchenAid Microwave Ovens
I have a GE range JGB290MEN2BS. I relaced the broiler igniter p.n. WB13K21 My question is: should the ingniter continue to glow after the flame ignites. i assumed it would go off when the flame came on...
No, the igniter continues to glow. Current has to flow through the igniter to allow the main valve to open and allow the gas to flow. So the igniter will be on all the time while the broiler is operating.
Dec 25, 2010 | Microwave Ovens
When trying to light oven or grill the clicking of the ignition does not stop! Any ideas? Parkinson cowen chichester thanks
your oven switch is sticking, causing the clicking, if you can open the range top to see that switch, i would pull off the wire to that, until you can have it replaced
Dec 19, 2010 | Microwave Ovens
Hi, got old Eurolec Gas oven/hob. Hob lights up fine. Was cooking in oven all morning, no probs. Tried to light oven for evening meal & gas will not stay lit, goes out once ignitor & temp' dial...
Hi, your thermocouple is faulty, it is the little probe like thingy that sticks up into the pilot flame. It is there for safety purposes, detects flame and holds a valve open magnetically to allow the gas to pass through. Try giving it a clean with a scourer, sometimes works, or your pilot flame is not big enough, could be low on gas or unit needs a service Kristian KJ Tech
Sep 15, 2010 | Microwave Ovens
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Electronic ignitor does not recognize that flame is on thus does not stop clicking
A generic troubleshooting response would be...... if the burner won't stay on, either the igniter or the ignition module (or both) are bad. If the burner ignites and stays on but the spark module keeps trying to ignite, the module must be bad.
Sep 14, 2009 | DCS Microwave Ovens
Integra fan convection - rsa regency
you might be able to just clean the ignitor to get it working again. Take it out and give it a good cleaning. If that doesn't work then it could be your spark module. If it is your spark module it will have to be replaced. I have replaced spark modules and ignitors of ovens or ranges that you can no longer get parts for with whirlpool modules and ignitors. There are basically two types, just make sure you get the same type. One type , typically used by GE uses a continous ignitor that glows when it works, and Whirlpool (on most models) uses the spark module and ignitor that makes the clicking sound like your oven did for ignition.
Jul 24, 2006 | Bosch HLK4525GB Convection/Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
