Question about Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi...
Kholer faucet won't move from sise to side
Our Kohler sink faucet model r10433-cp has been installed for about a year and has increasing become very hard to move/pivet from one side of the double sink to the other. I remove it and everything look ok but still has the same problem after it was reinstalled. Any suggestions as to how ti fix it?
Thank you in advance.
  • ElderDawg Jul 15, 2009
    Thanks for the info. I finally had to call Kohler's customer service. They kindly sent me that o-ring you mentioned and a replacement plastic bushing that is under it, plus a tube of lube for free as part of the life time warrenty. I fixed it in about 45 mins. and all's well for now.
  • Anonymous Mar 15, 2014
    It is hard to swing side to side.
  • 297 Answers
Under the neck there is a o-ring it is starting to go bad.call a plumber to fix if you can't do it yourself.
Posted on Jul 15, 2009
  • Bill Johnson Jul 22, 2009
    can you rate my answer please
  • James Evans
    James Evans Aug 31, 2014
    How do you remove the neck/body to get to the o-ring?
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
The handle function is stiff. Does not move smoothly and easily. How to lubricate?
You need to take the handle off and remove the cariridge and then place a food grade lube on all the moving parts. The replace the parts as you took them off.
You may fine your going to have to replace the cartridge after you remove the old one. So just dont do it at a time when the store are not open. Unless you have valves under the sink faucet
Best of luck
RJ
Sep 04, 2011 | Kohler K-12176-CP Fairfax Single Handle...
Just lost pressure. Only a very small stream of water comes out, hot or cold. All other faucet in the house work fine. It is about 1 1/2 years old. R10433-CP
First try the tip ariator. it can plug up. then you have to check the inlet system, which includes shut off valves, hoses to the faucet and the cartridge. It is the cartridge that has the small openings, but shut off valve seat material falls back into the feed channel. I usually remove cartridge, cover with a towel and turn on feed water briefly. Often I get little pieces.
Oct 27, 2010 | Kohler Model 10433: Fort® Single-control...
I had a dripping Kohler Finial kitchen faucet
Any bit of dirt or grit in the line will get caught in the cartridge if not flushed properly.
Apr 18, 2010 | Kohler K-16109-4-CP Revival Kitchen Sink...
Kholer 10416 faucet won't stay tight on my granite kitchen counter. Is it missing a washer or does it need a different bracket under the counter.
I would definitely try adding washers from under the sink. Has it been caulked? Caulking will help to fasten the faucet to the counter.
Mar 18, 2010 | Kohler Plumbing
Cannot remove Kohler ceramic valve
is this a single handle faucet. If not the part goes in under the handle
Nov 02, 2017 | Kohler Model 10433: Fort® Single-control...
Kohler Model 10433: Fort® Single-control Pullout Kitchen Sink Faucet Wi... Logo
2,705 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
