Question about Whirlpool LSR5132PQ Top Load Washer
My whirlpool washer, started making a clicking noise from the inside, the just stopped working. I see there are some metal clamps inside of it.. how can i fix this problem?
  • c_belez313 Jun 28, 2009
    It stopped right after it filled up with water
    I was messing around with the metal ring thats right under the bowls top, (i think its for to make sure water gets out) anyway, it started working again, but when it entered the spin cycle, it sounded like it was about to tip over, shaking violently. Would this mean it was just off balance?
  • 351 Answers
What cycle did this happen? does it go through a whole wash cycle
Posted on Jun 28, 2009
  • Mark Nichols Jun 28, 2009
    so it does not agitate? put it in spin and see if it makes the same noise?
  • Mark Nichols Jun 29, 2009
    could be... sorry really didnt understand this question to well..
My Whirlpool LHW0050PQ front load washer's tub is making a clicking noise when turning. It almost sounds as if there was a metal part stuck between the tub and the inside of the machine. Is ther
Have you lost any underwires in any bras? Would be my first check, as years ago I had a similar sound & it turned out to be part of a broken underwire from my bra, I manage with a bright torch & a pair of tweezers to locate the offending object by slowly turning the drum with my hand & the teasing the metal through one of the drum holes & retrieved it, I wasn't ever going to pluck my eyebrows with the tweezers again but hey, they're cheaper than washing machines!!
I hope this helps, let me know if I can help any further...
Feb 28, 2018 | Whirlpool LHW0050PQ Front Load Washer
My washer started by spining faster then normal and then it started makeing a loud knocking noise and now sounds like metal rubbing metal. Everything else works fine just can't spin anything.
SOUND LIKE INNER TUB AND BEARING AND SUPPORT SHAFT...# W10250573 $364.00 INNER TUB AND SHAFT..REAR TUB AND SEAL#8181912 $224.00 VERY TIMELY AND EXPENSIVE REPAIR CHECK WARRANTY ON WASHER
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washer not drain, with clicking noise
If it has a filter, clean it out and start again
Mar 15, 2017 | Whirlpool LSR7333 Top Load Washer
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Ginding noise during agitation
From the GE site.....
Front load washers and some compact model washers do not come with a shipping rod. According to the Installation Instructions for these machines there are 4 bolts, 4 yellow plastic spacers, and 4 metal "p" clamps that need to be saved and reinstalled before moving the washer to prevent any damage to the machine.
Jan 31, 2009 | GE Profile WPSR3120WWW
Whirlpool washer agitates but makes a very loud noise
It sounds like the agitator teeth, that are plastic, are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, and check the circular teeth inside, to see if they are worn out. These plastic teeth are the agitator part of the washer, where as the spinning part is a metal set of teeth, at the bottom of the agitator. You see the metal teeth, when you take the agitator completely out. You will have to replace the agitator if the teeth are worn out.
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
Nov 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Duet Sport Front Load - Spin Cycle Noise
Had one do this. Turn machine around look at bottom two corners. Machine comes with metal rods to stabilize drum during shipping. Installer forgot to pull those out on mine. Once I removed them noise quit.
Jul 07, 2008 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
78 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
