Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Why does electric mower shut off my breaker when switch is turned on?
  • 520 Answers
You are probably overloading a busy circuit and the mower is pulling enough to trip breaker....try another source that is hopefully more than 15 amp rated and not running the rest of the house. otherwise mower motor could be failing and shorting or drawing too much amps(electrical current) overloading and tripping breakers
Posted on Jun 28, 2009
Can I remove a breaker from panel box cap the wires turn electric back on till I go get a new breaker.
You can but why not get a new breaker first. Once into the panel and you're done.
Nov 28, 2014 | Electric Electrical Supplies
Husqvarna floods when starting hot
Your module is an electrical unit. Part of it acts like a breaker in a fuse box. A breaker over heats and shuts off when cooled it works again. Like a built in safety switch so you don't start on fire.
Jul 03, 2014 | Husqvarna Garden
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
Part way through a mowing my electric mower trips breakers deck is clean
motor is probably drawing to many amps and overheating have to change voltage regulator
May 22, 2013 | Garden
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
I have a 60" Lesco
If it were me I would check the PTO switch with it running and use a dvm or test light to see if switch is working or defective , you could just have a bad wire connector at the switch or at PTO clutch ....look for discoloration or spread terminals, good luck
Aug 01, 2011 | Garden
Ac unit wont start
Sounds like a classic case of a burnt/pitted compressor contactor. The contacts can get pitted and sometimes burnt. This can cause them to stick and the unit will not shut off unless you shut off the circuit breaker. When you shut off the circuit breaker, the contacts would have cooled down which could have led to the problem you are now experiencing......will not come on. Open up the electrical box. Look near the bottom for a brown or black part with the wires from your circuit breaker wired directly to it. This is your contactor. In the center is the piece that moves up and down to allow the electricity to go to your compressor and fan motor when there is a call for cooling. Check to see if it looks burnt or otherwise damaged.
Apr 04, 2010 | Carrier 38CKC048 Air Conditioner
Inbuilt breaker disconnects power to the motor, motor is cool.
if it is tripping as much as you say, it needs to be replaced..... just as a breaker in your house, if it starts popping all the time and there is no problem you have to replace it. replacing it is not all that hard, if you are handy with tools. finding it maybe a little harder. you can check at local mower repair shops. with it unplugged, make sure the blade turns without binding also.
Feb 03, 2010 | Electric Lawn Mower
Electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Aug 20, 2009 | Craftsman Garden
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
123 people viewed this question
Top Briggs & Stratton Hammering Experts
rlev_7
Level 1 Expert
JOHN LAPIER
Matt Olenzek
Matt Olenzek
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
