Question about ASUS P3B-F Motherboard for Slot 1 CPU
No light on Motherboard Asus P3B-F - ASUS P3B-F Motherboard for Slot 1 CPU
    Problem Solver:
  • 15 Answers
If yo have no light on the motherbaord this means that the PSU (Power Supply Unit) is either faulty (so no delivering 5v to the motherbaord) or is not plugged in properly in order
1. does something else that works somewhere else work in the plug you are using for your PC (yes goto 2 No you need an electrician to look at you mains sockets)
2. Does PSU have an independent Power Switch is it ON
3. Unplug and plug back in you power leads. (does it work OK if not goto 4)
4. Does the power light come on your VDU if yes swap the power leads from VDU to PC (does PC power up and screen dead if yes replase fuse in Plug - like for like - if no goto 5)
5. Problem is most likely with PSU replace unit for another one the same - be sure to get the same number of ATX connectors you can get a 20 and a 24 pin variant
Posted on Jul 07, 2009
I upgrade old machins and give them away for charity. I have two P3B-F motherboard machines that I have upgraded to 1G, They will not boot up nor will they even run to the point I can enter setup. One...
Make sure the RAM is good, and google it to see if the motherboard supports it. Also, make sure the slots are clean and the RAM sticks are also clean. You may even clean the pins of the sticks using a cotton cloth and alcohol. Sometimes dust and fingerprints on the contacts can cause the RAM not to be recognized by the motherboard. As I remember, the BX motherboards are quite old so probably the RAM slots are full of dust, and you'll need to clean them up either with a vacuum cleaner or a brush of some kind.
If this was helpful and informative please vote with a Thumb Up. Thank you.
Jan 30, 2011 | ASUS Intel 440BX Chipset P3B-F Motherboard
Driver for lan
You would go HERE, and enter the P38-F in the search box, and it will give you all the drivers available.
Thanks
Mark
Apr 17, 2010 | ASUS P3B-F Motherboard for Slot 1 CPU
Need manual for a d33007 m/b
Here is what I found on Web? Good Luck :0)
http://www.user-guides.co.uk/download/diagram/diagramd33007/diagram-d33007-motherboard.html
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English
ASUS 1394 P3B 1394 IEEE 1394 Motherboard USERS MANUAL English Additional information on your ASUS Motherboards MainBoards. This manual has not been listed as either a service or user manual for your 1394 but may be of interest. 2 ASUS P3B 1394 4 ASUS P3B 1394 5 SOFTWARE SETUP 63 6 ASUS P3B 1394 6 SOFTWARE REFERENCE 7 APPENDIX 93 94 Part De ..... diagram d33007 motherboard ... lots more information here
Download And CD Available
Nov 11, 2009 | Computers & Internet
Rebuilding need manual ,I want to upgrade
I foud your documention on the Asus website:
Steps to get your manual:
1) Visit the Asus Website HERE
2) In the three drop down boxes, select Motherboard, Slot1, and P3B-F
3) click " Search " button
4) If prompted, select "win 9x"
5) Scroll down to " Manual "
6) expand the " manual " section, download from one of the mirror sites
Nov 02, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
Asus P3B-F Motherboard
Download a manual from the ASUSTEK website, I have read many forums related to issue's with ram and from what I have learned with the ASUS boards is that dependind on the bios and the model, each slot, for some unknown reason can only recoqnize a maximum of 128MB per DIMM slot? My board has 4. For example, no matter what I install for Ram the motherboard will only read 512, some of the forums on ASUSTEK reccomend reflashing the bios with an updated one, but now, with the age of these computers i find it difficult to find a Bios upgrade. It is ridiculas, the Bios should come from the manufacturer ready to handle the maximum Ram of 1GB, which is my case with the ASUS P3B-F Pentium 3 with a 850MHZ processor.?????????
Jun 08, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
HELP WITH CONFIGURING A NEW OPERATING SYSTEM?
I have encountered the same problem with yours. But luckily i was able to manage to solve the problem. What i did was, i remove my Hard Drive and install in another pc (working pc) and made it as a slave. After that, i boot the pc then go to My Computer folder, i use the tool Scandisk and set it on automatically fix errors.
After this procedure, i remove the HD and install it back to where it was originally installed. Then I install new OS and it works..
I doubt that it was the virus who made my HD go wrong.
hope this helps.
Mar 22, 2009 | ASUS Intel 440BX Chipset P3B-F Motherboard
Only cursor displayed in monitor
This is because you have not selected boot devoce priority to HDD first or ur hDD is not have aCTIVE PARTITION
Dec 19, 2008 | ASUS P3B-F Motherboard for Slot 1 CPU
BIOS flashed with wrong version
Remove the CMOS battery will reset the bios ( not sure how you could have installed incorrect bios it would tell you it the wrong bios )
Jul 18, 2008 | ASUS Intel 440BX Chipset P2B Motherboard
HOW MUCH RAM CAN I PUT IN
depends on how many ram slots you have.. windows can support up to 4 giggs of ram, and mac i believe is 16 giggs. you can get up to 2giggs per stick of ram i believe
Dec 25, 2007 | ASUS P3B-F Motherboard for Slot 1 CPU
Computers & Internet Logo
670 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
