My sewing machine started to have problems with the lower bobbin. No matter what I did then bobbin would unwind and jam up.I received the E6 error a few times now. ALso, the upper thread seems not to have any tension at all. there is no difference anywhere on the dial. I threaded it properly. I cleaned out the bobbin case ( which appears to be scratch free) I tried different bobbins.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension at the midway point and retest the machine. Then adjust the top tension until the two threads meet in the middle of the fabric.
I think that you are putting the bobbin in wrong, make sure that it is feeding thread the right way, look at your manual and see if this is the problem.
SOURCE: Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
SOURCE: threading lower bobbin
There are some different bobbin cases for different machines but the one you have is a pretty common one with a finger sticking out on top. If you examine the bobbin case you will see a slot on the side of it and there is another piece of metal screwed onto it. This is the tension they are describing.
To thread it properly, turn the bobbincase upside down and insert the bobbin in the case so you can see it. Place your thumb on top of the bobbin and pull the thread through the slot on the side of the case and under the piece of metal(the lower tension) which I described to you earlier.. When you have done that, remove your thumb from the bobbin and pull on the thread. It should have some tension on it.
Next,placing a thumb or finger on the bobbin to keep it from falling out, turn the bobbin case over.
Keeping the finger sticking up lift the lever on the
front of the case and insert the bobbin and bobbin case onto the spindle inside the hook assembly(The part that is in the bottom of the machine that turns when the hand wheel is turned.) Don't worry about the thread that is sticking out.
Holding the upper thread under the presser foot ,turn the handwheel towards you until the top thread pulls the lower thread to the top. Pull the thread to the left of the machine, insert your fabric, lower the presser foot and begin sewing
One more thing , The finger sticking up on the bobbin case will go into a slot on the ring holding the hook inside the machine.
Hope this solves your problem.
Be sure you thread the upper part properly. It should go through the tension, then the take up lever and then the needle. Tension should be set at around 5
sewman7
SOURCE: thread knotting around bobbin case
hello, I had the exact same problem and could not find the solution until i took my machine to my sewing sensei and i solved my tedious problem. It was actually not a tension problem at all but a threading problem. Make sure you have threaded your bobbin correctly and that when you pull on the bobbin thread that the bobbin turns the right way. (mine must spin anti clockwise to work) Make sure that when you pull up the bobbin thread using the needle that it is not over the feed dogs connective bar but under it. A big problem when the thread gets caught around the bobbin case wheel is that the thread is looped around the feed dogs once and that causes the thread to get caught around the bobbin wheel. In conclusion, thread the bobbin correctly and read over your instruction book before spending the money to get it fixe in s shop.
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
SOURCE: tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
