Question about Toshiba 23HLV85 Television
Front red light comes on when pluged in, but no power the the tv
No power to the tv or dvd even though the red ligt on the front of the unit comes on when pluged in. I fuse issue on the power board?
Thanks.
  • 822 Answers
Be sure all units are auto volt. if you plug units 110V to 220V it might be damage or fuse will blown up.
Posted on Jun 28, 2009
Haier tv wont turn on
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 18, 2015 | Haier Televison & Video
1999 sony 53 in rear projection tv
Hi mike, have you tried unplugging your TV for 5 minutes, and then pluging it and trying again?
Dec 31, 2007 | Televison & Video
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
Dri have 26 inch flat screen tv and what the problem is that it will just shut off and it will take a day or to power up even the red ligt to let u no that its pluged in dosent even light up but leaving it...
its easy fix if you can use a soldering iron.....
needs new caops on the power supply board.........
if you cant use s/i ...
obtain replacement p/s/b from ebay..........
cheers
Apr 11, 2011 | Element Electronics Televison & Video
Mitsubiushi wd52525 nstatys ligts keeps blinking green. Lost power when the TV was on and now i have a status light that just keeps blinking green.
Unplug for a minute, when pluged back in light should blink for a few then go out, should be able to power on after that!
Dec 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Nothing on unit front display but Red Record light (solid)
how do you hook a dvd player up to a Sanyo sdtv model ht27547 tv ?
Jan 18, 2008 | Televison & Video
Not working
have you pluged the rca to scart in of your tv or vcr for picture check cables if you have rca to scart in or if you have rca to rca check for breaks in signal of plugs you'll need a converter for rca to scart all outputs will be on rear of unit. hope this helps
Jun 16, 2007 | Memorex MVD2022 DVD Player
Toshiba 23HLV85 Television Logo
369 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
