Question about National Little Tikes Hummer Yellow
Will only drive forward in 1st gear, 2nd gear and
Will only drive forward in 1st gear. 2nd gear and reverse stopped working. will sound like its running in 2nd and reverse, but will not move. what is wrong
  • Anonymous Mar 31, 2014
    It is like something is slipping both in reverse and forward
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Posted on Jul 10, 2009
Transmission issues on a 2003 Buell XB9S Lightning.
sounds like shift lever adjustment problem
take it into a service center and have it properly diagnosed and a quote
Sep 09, 2016 | 2003 Buell Lightning XB9S
Ninety eight ford explorer will barely accelerate from a complete stop until about twenty mph then it drives normally until it comes to a complete stop again However in reverse it runs and accelerates...
It sounds as though the transmission is slipping. You say it works okay at about 20mph, well by then it should be in 2nd gear. And you say reverse works fine. Reverse and 1st having no internal components in common, and in 2nd gear there is a band to assist the forward clutches. So it sounds like either the forward clutches of the low one-way clutch are bad. Take it to a transmission shop and ask them to road-test it.
Jan 24, 2014 | Cars & Trucks
Buick rendezvous gear shifts just fine but car won't move. No grinding shifting is smooth and flawless vehicle just will not move forward whether it is in drive, 1st, 2nd, or third gear. Reverses and
Sounds as if forward driving gears are shot. Different gears make vehicle move in reverse. I would ask if transmission fluid level when checked is in the operation range or full.
Nov 07, 2013 | Cars & Trucks
I have a 1998 Oldsmobile Bravada auto trans drive works fine but no reverse
Are you sure you have all 4 forward gears? Most of the time a no reverse condition also means 1st and 3rd only.No 2nd or 4th.If you dont have all the forward gears as i suspect , the reaction shell is stripped or broken.If you do have all the forward gears then these are the two most common reasons you do not have reverse.1 reverse input clutches are damaged or burnt 2 forward cltches have slipped to the point they are welded together causing a mechanical bind in reverse and also causing the transmission to pull forward in neutral.Let me know if i can help.Good Luck.
Feb 28, 2011 | 1999 Oldsmobile Bravada
Was pushing snow and heard aloud ping while in reverse and it quit pulling.all forward gears still work. sounded like a u-joint. believe me i no that sound.i drive it like i stoled it. lol.but thats what...
not sure if this is an automatic or manual transmission 1st (automatic)if all forward gears are still working what it sounds like is that the reverse drum in the transmission has come apart. which will eventually cause the forward gears to start to go if thats the case, the rapir for the reverse drum is internal the transmission will need to be rebuilt. you can just put a reverse drum, but my opinion is there will be more damage and while its out might as well rebuild the entire transmission. you didnt mention if it was 4 wd or not and only rarely have i seen a transfer case cause the same issue, once most recently in a f150 with a manual transmission i was working on the chain stretched so bad it lost reverse but had all forward gears. 2nd (manual) could have lost the reverse synchronizer whic again the trans will need to be repaired either with just a syncro or complete rebuild. hope this helps
Feb 04, 2011 | 1999 Chevrolet 3500
Only reverse works. No foward gears.
No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
Do you have manual 1st? If so, can you shift through the gears...i.e. manual 1st to manual 2nd then 'D' then 'OD'??? Only 1st and 2nd gears use the forward sprag unless the LO/Rev clutch is engaged...i.e. 1st and 2nd if in "drive". If you can shift threw the gears manually then, yes, your forward sprag broke.
If no manual 1st then your sprag is not what broke. Sounds like you blew up the rear planet. If you pull the pan and find chunks of iron and steel, then that is probably what happened. If you have reverse then it is not the pump. If the pump was bad you would have no line pressure and it would slip in rev. or no rev. Not the beef sun shell either because you have rev., a broken sun shell would cause no 2nd, 4th and rev. gears. Either way the trans needs to come out and torn down and it will be easily found what went. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1991 GMC C1500
Tranny will go in reverse fine but it has no forward gears.
she's pooched, your forward gears in an automatic are completely separated from the reverse same with a standard either way your on your way to the tranny shop
Jun 29, 2009 | 2000 Ford F250 Super Duty Crew Cabs
1994 Ford Ranger won't shift into drive
In 9 out of 10 cases when I see this problem in the ranger, it is the planetary gear in the transmission. It is made of the cheapest metal available. It breaks usually from going to park before the truck stops or switching from reverse to drive while still rolling. Just a Idea , But I hope it isn't that . Reverse will work fine for a while, and have no forward gears.
Jan 15, 2009 | 1994 Ford Ranger Supercab
National Little Tikes Hummer Yellow Logo
818 people viewed this question
Top National Toys Experts
romney2012
Joseph Hoffmann
Adam Fjeld
Adam Fjeld
Are you a National Toy Expert? Answer questions, earn points and help others
