Home | Agfa | SnapScan 1212p Flatbed Scanner | Driver needed to upd...
Agfa SnapScan 1212p Flatbed Scanner
Problem for Agfa SnapScan 1212p Flatbed Scanner
Driver needed to update my Agfa Snapscan 1212p to use with windows Vista
By Urlaur on Nov 07, 2007
I have a New Computer with windows Vista is it possible, to get a driver so I can operate my Agfa Snapscan 1212p with the new computer?
the new scanner printer I have is NOT as good as my faithful Agfa Spapscan 1212p.
S. F.Tollemache.
sftolly@eircom.net
Same Problem
Aug 30, 2008
-   tengo el windows vista y quiero operar mi AgfaScan 1212p-   Guest
May 19, 2008
-   I have an Agfa Snapscan 1212u and would like to know which Twain Drivers I can use with this scanner under Windows Vista. -   m0nde
May 12, 2008
-   agfa snapscan 1212u
i've installed Scanwise 1.2 and 2.0 (from the agfa site) but they don't work anymore under XP.-   Guest
Feb 10, 2008
-   I've fixed mine so it works with vista fine. If you download the latest driver from the agfa site (the SnapScan software), or install your original from the disk that came with the scanner, it will work with Vista if you right click on the program, go to properties and change compatibility mode to windows 95. You then have to run the scanner software in admin mode. Mine now works fine and I've been scanning in all day... Hope this helps.-   Ecrodorias
Feb 04, 2008
-   I have an Agfa Snapscan 1212u, and it will not run in windows Vista. Will any other twain driver do?-   Guest
Best Solution
posted on Feb 10, 2008
Very Helpful)
robofinz
Rank: Apprentice
Rating: 98%, 7 votes
Agfa have a 1212u driver on their site for XP and always have had although they pulled out of scanners years ago.
Was this helpful?
Yes
No
Solution #2
posted on Nov 08, 2007
Helpful)
tom19511
Rank: Guru
Rating: 85%, 2137 votes
Agfa will not make XP or Vista drivers in the future for these scanners as it stopped its desktop scanners and digital camera business in September 2001.
Was this helpful?
Yes
No
Solution #3
posted on Feb 23, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
el scanner mio funciona en xp si se sellecciona compatible con windows nt
Solution #4
posted on Dec 10, 2008
Very Helpful)
azurita
Rank: Apprentice
Rating: 100%, 3 votes
hi
I from Chile and the solution I write in Español
tienen que descargar el driver de la pagina de agfa http://static.agfa.com/digicam_scanner_drivers/
luego renombrarlo cambiando la extensión exe a zip y descomprimirlo en alguna carpeta,
colocan instalar manualmente y dan la dirección de la carpeta donde descomprimieron el archivo,
win da una alerta que el driver no esta firmado, proceden y con esto queda el driver instalado sin incompatibilidad, pueden revisar el “administrador de dispositivos”.
Para scanear, sobre el icono del scanwise, colocan propiedades (boton derecho del mouse) y en compatibilidad colocan con win95
no olviden instalar el driver para que se instale el scanwise
suerte y saludos
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Agfa SnapScan 1212p Flatbed
Questions and Unsolved Problems for Agfa SnapScan 1212p Flatbed
Do you recommend Agfa SnapScan 1212p Flatbed Scanner?
Answer
Answer
it powers on, adjust s positions and then turns off
Answer
snapscan 1212u It is completely installed and a notice says it is "ready to go" , when I... (More)
Answer
my snap scan 1212 flatbed power will not stay on. I use it a lot over the last two weeks. Now today... (More)
Answer
Is it possible to get this problem solved for free?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Agfa SnapScan 1212p Flatbed...:
Top Scanner Experts
Rank: Guru Guru
Solutions: 1435
Experience: Self taught, Keep up with the manufacturer's service manuals, Beta Tester
Ask Me
Find more Scanner Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
