On the back of the block that the roller moves on is a 9/16 bolt . Loosen that and move the block down , when you have it adjusted right it will stay engaged but release easily If you can't get it adjusted that way it is probably time to replace the belt ..
Sounds like your belt adjusting block is too high. When engaged the center line of the roller should be just forward of the corner of the block. If the block is to high the roller moves to far forward and becomes very hard to release. There should be about 3/8 inch between the front of the roller and the face of the mounting bracket.
SOURCE: troy bilt horse pto clutch will not disengage
The problem is lack of lubrication in the pto coupling. Losen the two swing bolts carefuly,block the front under the motor. Separate the tine transmision from the housing and grease both sides with as much grease as you can work in. Work the lever as you do this. Should fix the problem.
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
SOURCE: Old Troy Built with model #HH60-105106F. What is
Try partstree.com. It helped me to identify what I needed.
SOURCE: how do i adjust belt on troy bilt horse tiller
How do I tighten a belt on a troybilt Tecumseh rear tine tiller?
