Question about Canon PIXMA MP210 Photo All-In-One Printer
USB connection problem
I have a brand new MP210 printer, which I've tried to connect to my computer. I've gone through the installation process, but get stuck at the automatic detection stage. The printer is on, the cable is connected at both ends, but the computer refuses to admit the printer exists. I tried manually assigning it to printer ports (LTP1-3 and COM1-4), but that didn't work. Help!
  • 21 more comments
  • Anonymous Dec 26, 2007
    Im having same problem with my Canon MP210 printer. It cannot detect my printer either. Ive tried different usb ports but still doesnt work.
  • Anonymous Dec 27, 2007
    Podłączam moją drukarkę PIXMA MP210 do portu USB i system WINDOWS XP wykrywa mi "nie znane urzadzenie" i dalsza instalacja urządzenia zostaje nie dokończona
  • Anonymous Dec 29, 2007
    During the installation, it is noted that the printer is installed and completed, however the green bar indicates it is hung. After I close the installation, the monitor goes crazy. The monitor works fine until I try to install printer...
  • pootle55 Dec 29, 2007
    I have exactly the same problem. I'm using Windows Vista, is this why? If it is, how can I rectify it?
  • kubotron Dec 30, 2007
    Vista 32bit - SAME here! Printer not detected !
  • Anonymous Jan 09, 2008
    I have the same problem with my printer. no connection of printer
  • CarolHa Jan 10, 2008
    Yup same problem here. I spent 1.5 hours onto canon technical advice who eventually came to the conclusion that the problem was my installation of Vista as apparently it should work fine. I explained that my installation was done by the manufacturer but all Canon could say was that I should contact Microsoft. This is DEEPLY frustrating as the printer works absolutely fine with my 3 apple macs and prints accross my network with no problem EXCEPT for this one Vista machine!!!!!
    Does anyone have any ideas??
  • Redas Jan 12, 2008
    I have also the same problem.
  • soltaylor Jan 26, 2008
    I am having the same problem also. It also happened with an HP 1315 printer that I tried to install.
  • leelee22 Jan 29, 2008
    installed software stops me st the connection part and says an error in the connection from the printer to the computer
  • Tim79 Feb 01, 2008
    The same problem for me. I have a acer notebook (5920g) and the printer won't be recognized by the installation software. It is found by windows vista but the driver is not found
  • jt89104 Feb 02, 2008
    I have the same issue. Installation hangs at the "printer connection" screen. Using 32-bit Vista. Going to try to call the Canon helpline but difficult as I will have to take time off work (only open 9am-5:30pm).
    I just had to throw away my expensive old printer as it isn't compatible with Visa, and now have this issue with my new one!!!!! grr!
  • jt89104 Feb 04, 2008
    I tried the solution suggested by Tim79 below... (press the maintenance button until "U" is displayed). Unfortunately it didn't work for me. Going to try to call the Canon helpdesk tomorrow.
    from jt89104
  • Lerry Feb 07, 2008
    I have bought a brand new canon MP210 Photo All-In-One Printer and have gone through the installation process. It prints on command and copies, but refuses to scan anything. My computer does not recognise the USB connection. I have tried restarting my computer, disconnected everything ndeven r-installed the progammes. What can i do?
  • Anonymous Feb 09, 2008
    i have a new mp210 and cannot get pass installing mp drivers.
    i have a usb 2.0 cable and my computer is set up for usb 2.0
    i have tried installing this 6 times at first it will say its connecting and then it will say its not
  • Anonymous Feb 24, 2008
    cannot download into laptop. keeps telling me to get in touch with manufacturer
  • Anonymous Feb 25, 2008
  • shecat Feb 28, 2008
    Every installs properly but it won't recognize the printer i have tried to reinstall and everything. Everything is plugged in but it won't pick up that the printer is connected. what do i do now
  • REBECA Apr 10, 2008
  • Anonymous Jun 22, 2008
    Canon PIXMA MP210 photo All-in-One printer
    I tried the instructions given in 'Start Here Easy Startup Instructions' to install the driver and other applications. But for some reason my laptop (Win XP SP3) is unable to recognize the printer after connecting the USB cable and then switching on the printer per instructions.
    If I connect the USB cable between the printer and my laptop even without connecting printer to power outlet, my laptop shows USB icon in the task panel in bottom right! Upon clicking the icon, it shows the following info :
    "A USB device has malfunctioned and exceeded the power limits of its hub port. You should disconnect the device"
  • napper548 Jul 04, 2008
    I have the same problem. My laptop does not recognise the printer
  • Anonymous Jul 04, 2008
    cannot go beyond the printer connecton
  • CarolHa May 11, 2010
    I'll check the drivers on my machine and see if they are the same.
    Does this mean that if it were possible to install extra usb ports of a different company that the printer might work? Probably not a possiblity for me as I have a laptop but might work for someone with a desktop machine.
Make sure that your connecting cable is USB 2.0 compatible.
I also went through this problem. Spent the better part of 4 hours dealing with it. Looked up lots of help, redid all installations to no avail. Came across a small reference as to the cable. Make sure that your cable is USB 2.0 compatible. I thought mine was. Went out and got a new one that said 2.0 on the label and now all works perfectly. Hope this helps.
Posted on Oct 19, 2008
I had the same problem with Windows XP. I was able to go to the Canon website and download an updated driver version which did the trick. ( -> Download Software -> Multifunctionals -> MP210). The later version that worked for me is called 1.00a.
Posted on Jun 23, 2008
Thank you Tim79,
i spent close to 5 hours trying to install my printer, and gave up for 2 months, until i found your soulution.
ran my install disk until promted to plug in the usb, but first i turned the printer on and went to u on the maintenence menu on the printer, then pluged in the usb. i am now happily printing.
thanks a ton.
Posted on Apr 18, 2008
Finally, after many hours, I have got it to work. I had to do two things.
1. Download the correct drivers from the Canon website (although the box my printer came in says Vista compatible, apparently the drivers for Vista are NOT on the CD inside the box. Stupid or what? Furthermore, there is a whole section of the Canon website dedicated to Vista drivers. But don't bother looking there, because Canon have decided to hide these drivers in another dark corner of their website). If you already downloaded drivers from the CD, first you need to uninstall them: go to Control Panel -> Programs and Features, then right-click on all of the Canon items and click Uninstall. Now you need to download the Vista drivers from the Canon website: go to -> Download Software -> Multifunctionals -> PIXMA MP210; choose the Operating System (Windows Vista) and Language (English), then download the appropriate drivers MP Drivers (1.00) (either Vista 32-bit or 64-bit).
2. I also had to get a new USD cable. The girls on the Canon helpdesk said this and I really did not beleive them, but it worked. The cheap one I bought on ebay did not work. I had to use the one from my old printer.
Hope that this is helpful for somebody.
Posted on Feb 06, 2008
Tim 79 you are brilliant!!!! thank you thank you thank you...i did what you said just before connecting the cables up when its prompts you to. i pressed the little maintenance button "in the middle", "second from bottom row of buttons" untill the display changed to a U press it 4 or5 times...and then connected it to the laptop as you said, and yeehaaa it worked!!!!
thanks you
Posted on Feb 03, 2008
I believe the problem is actually NOT with Canon or Vista, but the hardware inside the computer. It seems that for whatever reason, the maker of my USB/Motherboard drivers and Vista. I have a "Prolific PL-2301" hardware, which according to the download site doesn't have an update for Vista:
Right now I don't know what else to do - no one is taking responsibility.
Posted on Jan 20, 2008
After many hours I seem to have found a solution that worked for me. Unfortunately the manual didn't mention this at all. To install mp210 you have to press the maintenance button until the symbol U is on the LED display. After that plug the usb cable and it is recognized by vista and the drivers are installed. I hope this helps!
Posted on Feb 01, 2008
Hi. i have the same printer but i use it in windows xp. xp will know it itself.
Posted on Jan 01, 2008
Canon printer mp210 installation
That cable should be a usb-2 to a mini-usb. There should be a jack on the lower left as you look at the back of the printer for the mini-usb. The USB end plugs into a USB jack on the back of your tower. murf427
Aug 30, 2012 | Canon PIXMA® MP210 Printer
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching...
HI there,
I've personally gone through this circle...ugh.
First - Reboot your computer, and your cellphone. Turn them both completely off, and back on.
If that doesn't solve it,
Second - UNinstall everything to do with your phone. Drivers/Software/Etc. Once that's done, Reboot your computer. Now reinstall the drivers/software/etc, and when that's finished, plug your phone in, let windows find and install what it needs to.
If THAT doesn't work,
Sometimes windows installs your phone as a modem, and then as a usb disk. It may be possible that you machine recognizes the modem first and runs a process to coincide with that. FInd that process and kill it, and you should be good to go!
May 11, 2011 | Computers & Internet
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
USB Won't Connect...
upon installing, the printer must be disconnected first.. then connect it only when a prompt appears that you should connect it to the computer to continue installation.
Jul 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Canon pixma mp210
Canon downloads available
Please follow the steps below in order to install the printer driver for your PIXMA MP210.
First, please make sure that the printer is not connected to the computer.
1. Go to
2. Click on mp210svst100ea24.exe
3. Check "I accept" then click on Download software
4. Click again on the file m6A02mux.exe and save it to your Desktop.
5. After the download is complete, you will notice on the desktop a downloaded file: mp210svst100ea24.exe . Run mp210svst100ea24.exe and the setup will start automatically.
6. Follow the instructions from the screen in order to install the printer. When you will be prompted, please connect the printer to the USB port on the back of your computer.
7. After installing the driver, follow the same steps in order to download and install the MP Navigator as well: , mpnexwin105ea23-2.exe .
Feb 11, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
How to get a HP LaserJet 1018 to actually print something?
Yes it is a print driver problem, Unplug usb, delete all previous attemps at install, delete print software and drivers, Download and install correct driver from HP, plug in usb only when directed to do so.
Dec 18, 2007 | HP LaserJet 1018 Printer
Connecting Printer
Ideal way to install HP printers is remove USB cable before you start running setup process. when you run setup it will prompt you and ask to plug USB cable then proceed after connecting.
Dec 12, 2007 | HP PAVILION A6230N DESKTOP PC
Make sure if driver are properly installed...Go to bios and OPEN ALL USB PORTS...Check the USB HUB PORT IF THEY WORKING PROPERTLY!!!
Oct 17, 2007 | Lexmark X1270 All-In-One InkJet Printer
Canon PIXMA MP210 Photo All-In-One Printer Logo
788 people viewed this question
old marine
old marine
