Question about Hayward Powerflo Matrix 1 - Hp Above Ground Pool Pump
Water keeps coming out from under the lid of the pump
Replace the O-ring/re-lube it, if that doesn't work the actually strainer assembly may be warped, those come undone with the clip under the basket and just pop off - they are between $80-$100.
Posted on Sep 04, 2009
My Maytag Bravos washer. MVWXG655Dw0 doesn't complete the cycles and the wash light comes back on
Is lid locking? If not, lid lock should be replaced. If so, most problems I have found from that model comes from shift actuator under machine that shifts transmission from agitate to spin. Also be sure drain Pump is working and pumping water.
Sep 13, 2017 | Maytag Washing Machines
Water shoots out from under the lid of my toilet?
Water coming out from under lid there is two thing's to check. Fill tube from fill valve line may have come out of stand pipe and spraying under lid. And the next thing to check is the top of fill vlave maybe leaking and sparying water from it causing water to come out.
Mar 13, 2011 | Home
The pump lid has water coming out of it. is that normal? pump was off but water was gushing out when I opened it to put chlorine tablet in filter
Pull the lid back off and check the O-ring...it is not seated properly...reinstall the lid and you will be okay...
heatman101
Jul 13, 2010 | Intex 15' X 42" Easy Set Pool Complete...
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Haier washing machine E2 error
normally pump filter is the best place to start it could be jamed with a coin or hair clip if you take machine outside and empty it then lay it on its side you can access the pump take it off then stand up the machine and pour hot water into the soap draw check water should run out of bottom freely taking any fluff or bits with it now take apart the pump and clean it all out dry all components before reasembly if the machine still doesent wory could need a new pump
Sep 07, 2008 | Haier XQG50-11 Front Load Washer / Dryer
DGB-600 leak from carafe during brewing
My new Burr Grind & Brew grinds away but all I get is hot water?
Apr 14, 2007 | Cuisinart DGB-600 Coffee Maker
Hayward Powerflo Matrix 1 - Hp Above Ground Pool Pump Logo
97 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
