Question about IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner
USB Connection Hi i was wondering if you could help me i have an IBM Thinkpad 570 It wont let me save anything to a memory stick and i don't know why? Also i have a floppy drive but i dont know where to buy the floppy disks? One more thing i was thinking of buying a USB DVD RW?Do you reccomend this? How do i find out if my laptop is wireless? Sorry about all this? Fabienne Wilkinson Please reply to Fabienne_dasuza@yahoo.com
    Champion:
  • 208 Answers
Memory stick.. theres an issue with upper and lower filters doing that issue.
try http://www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
get the remover 4.6 remove all filters and retry. u might have to reinstall the soft for cdr burning again.
Posted on Nov 07, 2007
Saving to memory stick
In your E drive, (USB stick) make a folder called My Doc. Right click on your saved document and press Ctrl + C
Navigate to the folder n drive E and press Ctrl + V.
Nov 25, 2013 | IBM ThinkPad T20 2647 Notebook
Where does the stick go in an IBM thinkpad laptop
What do you mean by STICK?
Do you mean the RAM (memory) module/s?
OR USB memory stick?
What is the model of your Thinkpad?
Feb 08, 2012 | IBM Computers & Internet
My ibm thankpad 570 has a bios lock. wont let me in to bios or com.
To reset the BIOS read the information from this link.
In case of your IBM laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 08, 2010 | IBM ThinkPad 570 Notebook
Don't have a place to install the cd to download software trying to install netgear G54 wireless USB Adapter to IBM Thinkpad 2662
Find another computer with a CD-drive and a USB port.
Purchase a USB memory-stick.
Connect the memory-stick to that computer, and copy all the files from the CD onto the memory-stick.
Move the memory-stick onto your computer, and install from the files on the memory-stick.
Sep 27, 2010 | IBM ThinkPad X24 2662 Notebook
How do I restore my IBM ThinkPad 570 notebook to its original state. It has windows 2000 installed. It had a previous owner and it still asks for their password.
Hi
You'll probably need to take it to a reputable repair person or check my website www.micromend.com. The reason is that a program such as ERD Commander needs to be used to eliminate the password and then to restore the laptop is a 10 cd set with Windows and all the drivers. Good luck
Jun 03, 2010 | IBM ThinkPad 570 Notebook
Bios reset for ibm thinkpad 570
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
Sep 27, 2009 | IBM ThinkPad 570 Notebook
It has no network driver to connect to the internet how do I do that
Boot up your Toshiba laptop Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download There may be one or more driver files for each device, depending upon what device is installed on your IBM, download them all because only one will work with your device but you won't know which one until you install it and it works. Then copy the drivers from the Toshiba to a USB memory stick, then remove the memory stick and boot up the IBM R52 and insert the USB memory stick into the R52's USB port. Click on the USB memory device and double click on each of the device drivers. Each driver file will then expand and copy the driver files onto the C drive under a folder called Drivers. Open this folder to view the various drivers and run the Setup file for each driver.
May 13, 2009 | IBM ThinkPad R52 Notebook
IBM ThinkPad 560 VS ThinkPad 570 and ThinkPad X40
Hi there
Have a look here:
http://lists.nycbug.org/pipermail/talk/2004-September/002534.html
good luck
Feb 06, 2009 | IBM ThinkPad 560 E Notebook
F505 serial connection is dead.
Had the serial port working before? If not, try this, disable the infered port and click start choose IBM Thinkpad 760 open it and locate the com1 (serial) and enable it. It should work fine. Goodluck.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505 Digital Camera
IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner Logo
53 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
