Question about LG WM2688HWM TROMM SteamWasher
Is it normal not to see a water level in the washer?
    Genius:
  • 1,036 Answers
It can be. Some modern machines pride themselves on low water usage.
It's usually a bad sign if the water level is too high.
If clothes are not actually getting washed, or powder is not dissolving, check input filters by undoing hoses. The filters are just pushed into the inlet ports. Hot usually gets blocked first - so check water levels of a hot wash (90) compared to a cool wash (40) They should be the same.
Posted on Jun 28, 2009
LG WASHER WATER LEVEL
Newer washers use much less water than old ones,, energy efficiency etc.....
May 25, 2013 | LG Washing Machines
Roper washer rtw 4440 xqo very low water level for wash & rinse
You will need to replace the water level switch. Here is a link to the kit.
Here is a video to show you how to replace it.
Oct 21, 2012 | Roper Washing Machines
Have a GE washer model WWSR3090TAWW, S/N DT106239G. The washer overflowed, and repaced the water level switch. It tested okay. Later when a load was done, it did the same thing. I have checked...
Here's the acid test: If the water is overflowing, turn off power (timer off, unplug machine, or switch off breaker) and if water stops flowing, you have a bad water level switch or obstructed water level tube leading to the level switch. If the water continues to flow in when power is off, and the only way to stop it is to shut off the water supply valves, then replace the water inlet valve of the washer, which for your machine is part number WH13X10024 and generally goes for about $50.
Aug 21, 2009 | Washing Machines
Turn washer to normal or gentle cycle water will
add a pail of water if it starts adjust level control
Aug 11, 2009 | Washing Machines
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
Roper Top Load Washer Does Not Fill To The Top on ''Extra Large''
the water level switch can be adjusted to raise the water level but is not recommended. The level you have is normal.
Jan 24, 2009 | Roper RAS8445KQ Top Load Washer
Lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Oct 01, 2008 | LG WM-2277HW Front Load Washer
Frigidaire top load washer FWS933FS not filling
cold water has nothing to do with the water level this is the normal level for this machine
Apr 16, 2008 | Washing Machines
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Water level
Your water level is adjusted automatically by the machine, you dont have any control over this. What yu need to see is to keep your wall faucet fully open before the wash, also check whether the pressure is good. It is normal that you see a low level thru your glass in machine............
Dec 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
